Sonic Cleaner
47 replies to this topic
#31 dodge trucker ONLINE
dodge trucker
  • 2,683 Thanks
  • 3,335 posts
Posted December 27, 2017 - 10:24 AM
I was thinking of getting the 6L.  I don't think Id need a 10.
How many times can you run the machine on the same batch of solution?
#32 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted December 27, 2017 - 10:40 AM
I figured to go with a 10L due to the higher wattage of ultrasonic power (240 watts).
  • Mark 149 J. said thank you
#33 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted December 27, 2017 - 03:48 PM
Here's a pic! It looks small. I measured the tank and it figures out to 1.893 L, so they are rounding up the #'s. Got distilled water, but Simple Green is $13 a gallon. I have Purple Power. I'll give that a try at the above solution.
  • olcowhand, Alc, EricR and 2 others have said thanks
#34 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 9,985 Thanks
  • 3,233 posts
Posted December 27, 2017 - 04:05 PM
How many watts does it consume?
#35 jabelman OFFLINE
jabelman
  • 2,238 Thanks
  • 1,600 posts
Posted December 27, 2017 - 04:10 PM
I was looking at buying one too, I was told by a few to just use lemon juice in it
#36 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted December 27, 2017 - 04:12 PM
It says 80W.
  • 29 Chev and Mark 149 J. have said thanks
#37 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted December 28, 2017 - 08:49 AM
I found a couple coins and a brass clip to try this out with. Mixed 1 part Purple Power to 2 parts distilled water. Set the temp to 56C and 20 minutes on the timer. We'll see how it does. Noisy, must be the coins rattling in the basket.
  • olcowhand, Cat385B and Mark 149 J. have said thanks
#38 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted December 28, 2017 - 09:09 AM
Well it ran for the 20 min. and did a fine job on the nickel. The brass clip was cleaning pretty good. The quarter will need more time, but it has more shine around the edges.
In the pic of the unit above, the 2 digits next to the temp setting (56) is the actual temp. It got up to 62C, so it does warm things up. And part of the noise was the lid rattling on the basket.
  • olcowhand, 29 Chev and Mark 149 J. have said thanks
#39 jabelman OFFLINE
jabelman
  • 2,238 Thanks
  • 1,600 posts
Posted December 28, 2017 - 10:08 AM
try the lemon juice for us
  • KennyP and Mark 149 J. have said thanks
#40 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted December 28, 2017 - 10:10 AM
Haven't got any!
#41 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted December 28, 2017 - 10:20 AM
Think we need a list of what solution to use for what we are cleaning. Besides the Simple Green/Purple Power  we have lemon juice. What about White vinegar? And would any of this be full strength? If need be, once we have a list, I'll make a PDF for it so it doesn't get lost. Need some input here as I'm a complete newbie with one of these things.
  • Mark 149 J. and secondtry have said thanks
#42 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted December 28, 2017 - 01:15 PM
I don't have a sonic cleaner yet but I soak in vinegar so it should work good in the sonic cleaner. Full strength would be hard on aluminum
#43 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,691 Thanks
  • 1,510 posts
Posted December 28, 2017 - 01:26 PM
Vinegar and Lemon juice are basically the same strength acid so you probably won't see much difference in cleaning between the two.  I've used a product in my parts washing called oil eater.  I wonder how that would work.  I would love to see how your sonic cleaner works with the small carbs. especially the small inside ports that always get plugged with sand.  Thanks for keeping us updated Kenny!
#44 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted January 03, 2018 - 02:21 PM
Can't afford one yet but this kinda works.
#45 lrhredjb OFFLINE
lrhredjb
  • 799 Thanks
  • 616 posts
Posted January 05, 2018 - 05:31 PM
I just pulled the trigger on this one. It's a 2L with heater. Should be large enough for all carbs/parts I want to run through it.
I got mine today. I must say I'm kind of disappointed in the size. I had hoped to use it to clean the Amal monobloc carbs that are on my BSA. It doesn't look like it will fit in there. Should be ok for gt carbs. Guess I thought of a 2 liter soda bottle and figure that would be big enough. :boo_hoo:
