only way i know to show video
Posted December 14, 2017 - 07:40 PM
Posted December 14, 2017 - 07:48 PM
Its hard to say definitely but my thoughts are its from oil leaking from the overhead valve assy as I posted earlier remove the valve cover and retoe=rque the 2 bolts that hold the overhad assy to the cylinder head and reinstall the valve cover and see if that makes any difference.
Posted December 14, 2017 - 08:21 PM
Looks like a head gasket to me. I bet if you take the tins off you will see some spooge in between the head and block where its leaking, if its been leaking long enough you will see carbon build up.
Posted December 14, 2017 - 08:22 PM
BTW pictures and videos are a great way to show whats going on.
Posted December 14, 2017 - 09:29 PM
I would wonder if you have an issue with the valve guides. In any case you will have to dig in deeper to find out.
Posted December 15, 2017 - 07:08 AM
It looks like a crack is in the valve cover where the smoke is blowing out.. Look closely and you'll see it.. Clean the area up and repair it if I'm right..
Other than that a bad head gasket / poor rings is my guess. Perform a compression or leakdown test to evaluate the rings..
Good Luck!
Posted December 15, 2017 - 07:36 AM
Seems to me the smoke is coming up in between the valve cover and the engine tin. I'd remove the engine tins before doing anything to get a good visual.
Posted December 15, 2017 - 08:15 AM
Posted December 15, 2017 - 03:08 PM
Posted December 15, 2017 - 06:00 PM
This is a relatively simple and satisfying repair. You'll need a torque wrench, though.
