Tecumseh crankcase breather
techumsah motor
8 replies to this topic
#1 BolensH14 ONLINE
BolensH14
  • 1 Thanks
  • 10 posts
Posted December 06, 2017 - 08:26 PM
Putting my H14 back together I find I have a hose coming from the side of the block under the carb.  I assume it is a crankcase breather, but I cannot see where to connect the other end.  There is about 8" of hose but I see now where to attach it.
Ideas?
John
New Hampshire
#2 boyscout862 ONLINE
  • 12,185 Thanks
  • 8,896 posts
Posted December 06, 2017 - 08:49 PM
Its been along time but I think that that one connects to the air cleanner. Look up the manual. Good Luck, Rick
#3 Cnc OFFLINE
Cnc
  • 60 Thanks
  • 45 posts
Posted December 06, 2017 - 09:33 PM
If that is a hh140 Tecumseh it very well may be the same as the hh120. The hose coming out of the breather box covering the valve train on my hh120's just hangs straight down, but they are only about 4 inches long.
#4 Rainier OFFLINE
Rainier
  • 449 Thanks
  • 452 posts
Posted December 06, 2017 - 11:04 PM
That line goes to the fuel pump. Here is a picture. Sorry for the bad picture but it's dark out. The lower line goes to the crank case the upper is your fuel line in.
Edited by Rainier, December 06, 2017 - 11:06 PM.
  • Bolens 1000 and Sawdust have said thanks
#5 Hydrohusky OFFLINE
Hydrohusky
  • 37 Thanks
  • 37 posts
Posted December 07, 2017 - 07:57 AM
Agreed with Rainier......it connects to the fuel pump. The pulses from the crank case power the fuel pump.
  • Sawdust said thank you
#6 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,054 posts
Posted December 07, 2017 - 03:29 PM
Rainer is 100% correct thats the vacuum line for the fuel pump
#7 BolensH14 ONLINE
BolensH14
  • 1 Thanks
  • 10 posts
Posted December 07, 2017 - 08:17 PM
Great, but I don't believe I have a fuel pump.  Fuel line connected directly to carb from tank.
John
#8 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,054 posts
Posted December 08, 2017 - 10:07 AM
Someone must have removed it these all came from the factory with a walbro fuel pump
#9 BolensH14 ONLINE
BolensH14
  • 1 Thanks
  • 10 posts
Posted December 10, 2017 - 04:49 PM
Well this tractor doesn't have a pump.  The motor is a replacement short block (SBH)  I think this hose just vented into the atmosphere as there is no connection anywhere.  Guess I'll tap it into the air cleaner (please don't tell the EPA.)
John
