Wanted
John Deere 54 blade 420-430 mount frame
5 replies to this topic
#1 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 659 Thanks
  • 474 posts
Posted December 04, 2017 - 08:45 PM
Hello all, I am looking for  a JD 54 blade mount for a 420-430, the part number is AM102947, Thank You.
#2 KennyP ONLINE
  • 41,016 Thanks
  • 47,165 posts
Posted December 05, 2017 - 09:15 AM
If I looked it up right, you are looking for the ST552252 Frame.
#3 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 659 Thanks
  • 474 posts
Posted December 05, 2017 - 10:21 AM
I just need the part that mounts to the tractor, I have a complete 54 blade that is setup for a 300 series and I'm looking for a mount to put it on my 420.
#4 KennyP ONLINE
  • 41,016 Thanks
  • 47,165 posts
Posted December 05, 2017 - 04:38 PM
That is the part # JD gives to mount the blade on a 420-430.
#5 grnspot110 ONLINE
grnspot110
  • 4,324 Thanks
  • 2,697 posts
Posted December 05, 2017 - 07:41 PM
I had the same problem with the 420 I used to have, solved it by cutting the end plates off the mount & welding 1" into each side:  GARDEN TRACTORS 642 (Small).jpg   GARDEN TRACTORS 643 (Small).jpg   GARDEN TRACTORS 644 (Small).jpg
Might be an option if you have the tools & skills to do it!
#6 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 659 Thanks
  • 474 posts
Posted December 05, 2017 - 10:10 PM
If I was only going to use it on the 420 that is the route I would take, but I have a 316K that I can use the plow on so I want to keep the 300 series mount complete. I did get a frame squeezer from Als Welding but I see there is a fair bit of play between the 300 mount and the frame squeezer, hence I am looking for a 420 mount to swap the blade on to.
Edited by Leonard VanCamp, December 05, 2017 - 10:10 PM.
