My farm tractors
23 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,118 Thanks
  • 2,222 posts
Posted December 03, 2017 - 06:19 PM
I've posted before about my Farmall which has been patiently waiting for a new head gasket, got it started today without coolant to move it, and will soon be going to a buddy's place to have the gasket replaced. I recently bought a ford 9n that runs but needs new rims and tires. The 9n will get 8n hubs and 6 lug rims on the front, this tractor is and will stay 6v.
That's our farmall 706,and my Montgomery Ward in the background.
Edited by KennyP, December 03, 2017 - 06:32 PM.
3rd pic is my try at this.
  • Gtractor, hamman, tiretrx and 2 others have said thanks
#2 olcowhand OFFLINE
  • 43,143 Thanks
  • 32,005 posts
Posted December 03, 2017 - 06:23 PM
That is weird.  I saved your pic, flipped it, saved it, then added below yours and it still came out sideways!  I'll have Chris look into this.
  • adamjd200 and secondtry have said thanks
#3 olcowhand OFFLINE
  • 43,143 Thanks
  • 32,005 posts
Posted December 03, 2017 - 06:38 PM
Well, maybe Kenny has to be the designated "pic flipper"!  :D   Hoping Chris can give us insight on this.
  • KennyP and adamjd200 have said thanks
#4 KennyP ONLINE
  • 41,457 Thanks
  • 47,388 posts
Posted December 04, 2017 - 04:36 AM
I don't see a badge for that!
  • GTtalk and secondtry have said thanks
#5 GTtalk OFFLINE
GTtalk
    Administrator
  • 190 Thanks
  • 145 posts
Posted December 04, 2017 - 03:00 PM
#6 secondtry OFFLINE
secondtry
  • 2,244 Thanks
  • 1,582 posts
Posted December 04, 2017 - 04:37 PM
   Your flipped picture is fine on my computer. Don
#7 olcowhand OFFLINE
  • 43,143 Thanks
  • 32,005 posts
Posted December 04, 2017 - 06:52 PM
The 2nd pic in the opening post is the one I flipped.  Is that one correct on your screen?  It is sideways on my screen.
  • secondtry said thank you
#8 secondtry OFFLINE
secondtry
  • 2,244 Thanks
  • 1,582 posts
Posted December 04, 2017 - 09:04 PM
Nope, bottom one. Kenny must have fixed it. Don
#9 Cvans ONLINE
  • 7,460 Thanks
  • 6,468 posts
Posted December 04, 2017 - 11:03 PM
Funny you mention a 9N Ford. A neighbor stopped by and asked if I had a small tractor for sale as his 9N won't run right. Told him let's see if we can get his tractor running good before he worries about buying something else. So have to pick that up this week. Also an A International from another guy.
Keep us filled in on how your 9N turns out.
#10 adamjd200 OFFLINE
adamjd200
  • 2,118 Thanks
  • 2,222 posts
Posted December 05, 2017 - 09:04 AM
Other than wheels and tires not much is gonna change, it runs great and I don't paint my tractors as I like working them.
  • Cvans said thank you
#11 adamjd200 OFFLINE
adamjd200
  • 2,118 Thanks
  • 2,222 posts
Posted January 21, 2018 - 10:39 PM
Super c hopefully leaving for repair this week, all I've managed to get done on the 9n is procure a set of 8n hubs for the front, a new air cleaner pipe, I have a pair of 15" rims, my focus as of late has been car/truck issues.
#12 adamjd200 OFFLINE
adamjd200
  • 2,118 Thanks
  • 2,222 posts
Posted February 13, 2018 - 10:25 PM
Update, super c has new gasket installed problems there fixed, waiting for snow to go away so I can get to the trailer to pick it up. Have all parts for front wheel and hub swap on 9n, once again waiting on weather.
  • KennyP and Cvans have said thanks
#13 adamjd200 OFFLINE
adamjd200
  • 2,118 Thanks
  • 2,222 posts
Posted April 15, 2018 - 10:36 PM
Update, super c is completely rewired,new internal resistor coil, alternator installed(still have to install the belt), replaced ammeter with a volt meter, new battery, new fuel line and sediment bowl, will be adding a new temperature gauge soon. Ford is patiently waiting it's turn.
  • Alc and Cvans have said thanks
#14 Cvans ONLINE
  • 7,460 Thanks
  • 6,468 posts
Posted April 15, 2018 - 11:52 PM
   Good to hear your making some progress.That Super C should make a nice tractor for you. If they had a three point they would make a really nice small acreage tractor.
  Unfortunately the 9N here is in need of some serious help. Compression is 110-85-95-70 psi. While I had the plugs out each cylinder was pressurized while listening into the other plug holes to check for air leaking across the head gasket. Nothing was heard so I'm hoping the head gasket is OK. As the tractor was running rich I'm hoping the the valves are carboned up and not closing all the way. The carb adjustment screw did nothing so I put a kit in it and changed the plugs. At least it will start and runs now. It pulls without missing but still idles rough. Pulled the distributor, checked and reset the points. Going to load it up with Marvel Mystery oil and put it out in the field under load and hope that things will clean up and the compression comes back up.
  • Gtractor said thank you
#15 secondtry OFFLINE
secondtry
  • 2,244 Thanks
  • 1,582 posts
Posted April 16, 2018 - 12:38 AM
   When I did my 8N I got a kit, sleeves pistons, rings, wrist pins and keepers, valves guides springs seals and keepers, rod bearings, main bearings, gasket set. Had the crank polished.  It was in speck for 30 under. The kit was $150. Worked on it more of than on for a week. The crank was gone to town for three days. Cut a plate on my lathe for pulling the sleeves. Cut a pipe with the lathe to drive in the new sleeves. Worst part of the whole job was cleaning parts. Before I  worked on it the high cylinder had 60 lb. The standard fix for an old Ford tractor in this area when they wont start is to convert to 12V. Mine has started first try every time since the rebuild several years ago. and that with the same old 6V battery. I don't do any farm work with it, just snow removal and road maintenance. The same kit I used is now $388. The rest of the parts for a total rebuild can get very expensive.   Don
  • Gtractor, Alc and Cvans have said thanks
