kohler M18 govenor gear
1 reply to this topic
#1 veizter OFFLINE
veizter
  • 15 Thanks
  • 22 posts
Posted December 01, 2017 - 07:30 PM
something going on with the governor on the M 18 . doesn't work . I look down the oil fill tube and the gear on the crankshaft looks ok .  can I work on the governor , like change the fiber gear with the weights by just removing the side cover or does the case need to be split . . thanks for any help
#2 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted December 01, 2017 - 08:04 PM
The case needs to be split to work on it. Take the cap off and look in to see if the gear is spinning while it's running.
