Brinly Cultivator Upgrade!
16 replies to this topic
#1 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 28, 2017 - 05:12 PM
I bought the newer version cultivator some time back.
Having issues with the angle iron bending. So I decided to fix that. I bought this at the show last Oct.
Now I am modding the two into one.
Made up a mount to bolt those into.
And I will brace the daylights out of the final part!
  • olcowhand, grnspot110, hamman and 6 others have said thanks
#2 James Bosma OFFLINE
James Bosma
  • 1,317 Thanks
  • 652 posts
Posted November 28, 2017 - 07:25 PM
Looks like your on the right track
If Alice beats that up think its time to go and modified cat 1 attachments for Alice
#3 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 29, 2017 - 03:43 PM
I welded the mount up today.
Now I'm studying how to reinforce the angle iron. Thinking about something like this:
The mount is welded to 2.5" X .250" angle. I just don't want any flex/bend to take place. When I stick it in the ground, it will tear up the soil. I am not a structural engineer, just winging it.
#4 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted November 29, 2017 - 04:44 PM
I have seen a couple of those newer cultivators.  Built way to light but then again they were only made to go a couple inches deep, they're not subsoilers.
#5 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 29, 2017 - 04:56 PM
That was my next question. How deep should it go? 1" or more?
And how hard the ground is will make a difference! I am hoping to go 2"+ in 'soft/turned soil. Maybe 1"+ in non turned.
#6 James Bosma OFFLINE
James Bosma
  • 1,317 Thanks
  • 652 posts
Posted November 29, 2017 - 07:10 PM
Wonder if the braces on the angle iron would be stronger if they were straight instead of being on the angle, line of pull?
I'm no engineer either, just a thought
Everything looks good, keep up the good work
You should try to sell your used welding sparks on eBay
Actually seen that once
Depth I'm not sure
1 or 2 inches don't seem like much to me but what do I know, don't have a garden, I'm a carpenter
Thinking 2 to 3 inches, but depending on soil condition is always the biggest factor
#7 shorty OFFLINE
shorty
  • 5,475 Thanks
  • 5,258 posts
Posted November 29, 2017 - 07:15 PM
Interesting blender of making something work. I have a PK tool bar type of cultivater I like to get about 6" down with.
#8 Leonard VanCamp ONLINE
Leonard VanCamp
  • 510 Thanks
  • 389 posts
Posted November 29, 2017 - 07:36 PM
I have a older Brinly CC600 cultivator that in loose ground I can practically bury. On hard ground I make three passes with gradual weight increases on it.
#9 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 30, 2017 - 05:45 AM
Depth I'm not sure
I need to get the other one up so I can show why I want to angle the braces. It's in how I plan to mount this to the original frame work. Maybe this pic will help. I have circled in Red what parts I am using from this.
  • James Bosma said thank you
#10 James Bosma OFFLINE
James Bosma
  • 1,317 Thanks
  • 652 posts
Posted November 30, 2017 - 07:05 AM
I think I see the direction you are heading
#11 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 30, 2017 - 09:25 AM
It's going to be a blend of the two. It will be similar to this one:
Width will not be adjustable. I have it figured to be 48" wide at the rear to take out Alice's wide footprint.
  • James Bosma and Mark 149 J. have said thanks
#12 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 30, 2017 - 03:44 PM
I got some done today. Brought up to CC-550 and broke it down. This is what I need to mount the new parts to.
Put that in the vise to remove the 1" bolt. May be in the way.
Took the front cross part off and split it. This will strengthen the angle iron mount.
Got that all welded together.
Added the angle braces. They end above the 1/2" bracing.
Gotta got get some 3/8" X 3" bolts tomorrow. Then I can figure out what to do at the back end for bracing.
  • 29 Chev, James Bosma and Mark 149 J. have said thanks
#13 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 01, 2017 - 02:06 PM
I put things together today so I can figure out a brace system to the front. This thing won't need any extra weight, quite heavy already! I have keepers & wedges for 2 more teeth, that may be plenty. Just that they will not have sweeps on them.
Oh yeah, it's 48.25" across the rear points. Came out close to what I planned.
  • 29 Chev and Mark 149 J. have said thanks
#14 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 01, 2017 - 04:47 PM
I got all 5 teeth on it now. Two skinny ones are a bit longer, but they'll work. Have an idea for bracing the back ends, need to draw something up.
  • Leonard VanCamp, 29 Chev and Mark 149 J. have said thanks
#15 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 02, 2017 - 04:37 PM
Got the brace made up! And it works good.
Took it for a test run. Found out I had the add-on teeth set wrong. It was messing up at the mounts. The sweeps were acting more like a furrower.
This what I played in. Ran the disk over it all to smooth things out.
This is one of the sweeps. Notice the angle where it bolts in at.
I was using the lower bolt holes, creating a wrong angle for this to work. So I put the teeth back on in the upper holes and things look more like I think it should.
If I have any more issues with the mounts, I will get some 1/2" bolts and do away with the keepers and wedges!
