Bevel gear help needed
13 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted November 26, 2017 - 04:36 PM
I am trying to get this bolt out and it’s sunk into the washer and my air gun keeps jumping off of it. Any tricks or suggestions how to get it off would be greatly appreciated - also is this bolt standard threaded or reverse threaded?
Edited by sacsr, November 26, 2017 - 04:38 PM.
#2 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted November 26, 2017 - 05:09 PM
I don't know about the thread direction. I'm gonna say it's standard. You might try an air chisel to get it broke loose.
  • sacsr said thank you
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted November 26, 2017 - 05:17 PM
I don't know about direction but maybe if you grind away at the end of the socket the get rid of any rounding over in the socket right where it grabs the bolt.
Square up the socket so it grabs as much of the bolt as possible. I've done this by holding the end of the socket on the side of a grind stone on a bench grinder.
If you follow what I mean
  • Gtractor, sacsr and boyscout862 have said thanks
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Normal threads.
#5 Enginerod OFFLINE
Enginerod
  • 234 Thanks
  • 289 posts
Posted November 26, 2017 - 05:31 PM
If you are using an impact socket, try a 6 point chrome socket, they have less of a bevel and make more contact with the bolt head generally. Most of the time left hand thread bolts have an L on the head, also this bolt may have some type of thread locker on it, heating it up some helps to break thread locker loose.
#6 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted November 26, 2017 - 06:09 PM
If all else fails, weld a nut the same size to the bolt, welding inside the hole. Then you'd be able to get a good fit to a socket to remove it.
  • Dee, sacsr, dropped82 and 1 other said thanks
#7 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted November 26, 2017 - 06:10 PM
If all else fails, grab the head in a vise and turn the shaft. grab it with vise grips or a pipe wrench on a section of the shaft that doesn't come in contact to a seal or bearing. And like stated already heat would be good too.
Good luck
#8 CRFarnsworth ONLINE
CRFarnsworth
  • 4,675 Thanks
  • 2,146 posts
Posted November 26, 2017 - 06:47 PM
Yes... . what he said.    I've got a couple sockets that have had material removed from the end to eliminate the taper on the inside. It will allow the socket to put more of the flats against the  bolt head,  Do it to a six point socket.    Rick.
  • DH1, Gtractor and sacsr have said thanks
#9 Bob Mason OFFLINE
Bob Mason
  • 3 Thanks
  • 2 posts
Posted December 23, 2017 - 11:16 AM
I have rebuilt the bevel gears several times.  Never had a problem with that bolt, so I suspect a standard thread.
Does anyone know of a manual detailing how to rebuild?  I know there are shims available to set the gears, but no idea how to set this adjustment.
  • Dince said thank you
#10 Dince OFFLINE
Dince
  • 14 Thanks
  • 26 posts
Posted December 25, 2017 - 11:55 PM
I too am interested in Bob Mason’s request for a manual detailing a bgb rebuild. I have mine pulled apart, out of a Simplicity 725, and ought re-assemble it as properly as I can - new seals and shims. I have followed another thread, with interest, identifying the seals.
#11 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted December 26, 2017 - 07:15 AM
This is a simplicity repair manual .I believe it will show you.
http://gardentractor...epair-manual-1/
  • KennyP and Dince have said thanks
#12 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted December 26, 2017 - 08:46 AM
Section D starting on page 44 shows a lot of info and an assembly section.
  • drbish and Dince have said thanks
#13 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted December 26, 2017 - 10:07 AM
Well Scott, how did this all end?  Did the bolt come out?
#14 Dince OFFLINE
Dince
  • 14 Thanks
  • 26 posts
Posted December 26, 2017 - 04:09 PM
Many thanks to drdish and to KennyP for your prompt replies with the lead to the repair manual. It looks very useful, and I will now tackle the BGB with confidence!
  • drbish said thank you
