JD 316 engine running funny
37 replies to this topic
#31 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 510 Thanks
  • 389 posts
Posted December 02, 2017 - 08:56 PM
What is ‘egging on the cylinders’?
Means the cylinders are out-of-round, Onans will wear at the bottoms of the cylinders.
  • Dspangler said thank you
#32 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted December 02, 2017 - 08:59 PM
Ahh ok. Thanks for the tip!
#33 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted January 13, 2018 - 04:32 PM
UPDATE: I bought a new carb for the 316 as the one that was on it was missing screws and I didn’t want to work on someone else’s failed attempt at maintenance. Once the carb was installed, along with intake and exhaust manifold gaskets, she fired right up and sounded strong. Will test her out tomorrow to see if the new carb makes a difference.
  • KennyP and Leonard VanCamp have said thanks
#34 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted January 14, 2018 - 10:38 AM
UPDATE to my previous update: went out to plow, and now when the hydro lever is pushed past half the engine dies.. still runs a little rough too. Could I be looking at valve issues again? I noticed once that it back fired when I tried to go full on the hydro. Thoughts guys?
#35 secondtry ONLINE
secondtry
  • 1,879 Thanks
  • 1,379 posts
Posted January 15, 2018 - 12:00 PM
 Ok I went back through and re read the thread. Trying to get a handle on your problem. Noting the low compression is most likely the result of excessive wear of the cylinders, rings or both. For diagnostic purposes it doesn't make much difference which. If the engine is worn enough to lose that much compression then there is almost certainly significant wear in other parts of the engine. The fact that the compression is fairly even between the cylinders indicates that it is caused by more or less normal wear. A burnt valve or stuck ring only effects the cylinder it is in as far as compression goes. I believe from what you have said your engine is due for rebuild/replacement. You could try just replacing rings but if you take it that far apart it would make no sense not to inspect and repair the rest of the engine.   I have not rebuilt an Onan engine myself. Parts are extremely expensive.  Re-power with a less expensive engine is a possible solution but not a particularly desirable one. Don
#36 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted January 15, 2018 - 01:38 PM
Thanks for your input Don. At this point, I have to determine if i want to devote that much time and money into it, or unload it in hopes of finding another comparable machine. I hate to just get rid of it, but I don’t have the means and knowledge to rebuild it right now.
#37 coxhaus ONLINE
coxhaus
  • 120 Thanks
  • 137 posts
Posted January 15, 2018 - 01:43 PM
Try running some seafoam in the gas.  It may clean some of the carbon out which can be good or bad.  It is a cheap try.
#38 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted January 15, 2018 - 03:02 PM
Thanks! That’s the first thing I did with it however when I brought it home a few months ago.
