About to buy Case 444, couple of questions.
19 replies to this topic
#16 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,152 Thanks
  • 10,212 posts
Posted November 27, 2017 - 07:42 PM
I'm glad you took a pass.
#17 Curt7088 OFFLINE
Curt7088
  • 9 Thanks
  • 16 posts
Posted November 28, 2017 - 07:14 PM
I still feel like I could have bought it, but it would have taken too long to get it into decent shape aaaannnddd im pretty impatient.
#18 Curt7088 OFFLINE
Curt7088
  • 9 Thanks
  • 16 posts
Posted November 30, 2017 - 03:09 PM
one more question for youse guise.
I have seen some of the attachments such as the tiller that appears to use a hydraulic drive. How are these hooked up? pictures? The only tractors I have seen in person have a 3 pt. and that is it on the rear. I am intrigued...
#19 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,743 Thanks
  • 1,906 posts
Posted December 02, 2017 - 09:35 AM
Here's my 226 with the tiller. It's the same tractor as the 444 just 12" rear wheels and low profile front axle. Tiller attaches to the sleeve hitch on both machines. To run it, you need the rear pto valve. There's quick connects to hook up the hoses. It's by far the easiest tiller attachment to install in any brand I've owned. 20170425_203109.jpg
Here's my 444 PK. It has the J26 3 point and F27 sleeve hitch adapter. There was also a sleeve hitch offered for the 400 series that was 4" longer to clear the rear tires. Case made the 3 point for only the 400 series mainly due to ground clearance. The 200 series sat too low for proper geometry. Case made the tiller fit the sleeve hitch so all machines used the same attachments. Same goes for the mid and front attachments also.
Edited by dropped82, December 02, 2017 - 01:53 PM.
  • KennyP and chris m have said thanks
#20 Curt7088 OFFLINE
Curt7088
  • 9 Thanks
  • 16 posts
Posted December 03, 2017 - 11:47 PM
Ok, so to ru. Those, I would need a pto valve and a sleeve hitch adapter. Awesome. For some reason, I am stuck on the case 44x series out of all the tractors out there...
