Started on a new PK project
52 replies to this topic
#1 MNGB OFFLINE
MNGB
  • 2,623 Thanks
  • 1,569 posts
Posted November 22, 2017 - 08:54 PM
Hi all since winter is coming I decided to work on installing a snowblower on the 1973 Power King, its a 42" Haban that a fellow installed a 10 HP Tecumseh Snow King engine on and fabricated a mount to use it on his 4 wheeler, he said it worked but found a really nice 26 HP Simplicity with a 48" blower and cab so I got it for $75.00 didn't get around to doing anything with it last fall/winter so I figured now was time. I shortened the hitch mount and fabricated some rear hitch mounts and welded them to the hitch assy I'm temporarily using the front hitch parts from one of my PK dozer / snow blades. Got it hitched up to give the lift a try and it works good and without fine tuning it will lift 6" that was yesterday didn't get a lot done today other than removing the carb ( its a Tecumseh and has sat for 18 months so it needs a cleaning) and cleaned it didn't get it completely reinstalled but it should work iit is heavy and you can tell that in the steering so will be putting the wt box on the rear of the tractor when using it.
HPIM2511.JPG HPIM2512.JPG HPIM2514.JPG HPIM2515.JPG HPIM2550.JPG HPIM2551.JPG HPIM2554.JPG HPIM1654.JPG HPIM1655.JPG
Edited by MNGB, November 22, 2017 - 09:14 PM.
  • grnspot110, jms180, KennyP and 5 others have said thanks
#2 jms180 ONLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted November 23, 2017 - 12:20 PM
nice project and nice price you got it for. I look forward to seeing it blowing some snow
  • MNGB said thank you
#3 jms180 ONLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted November 23, 2017 - 12:24 PM
Oh forgot Happy Thanksgiving hope the weather is nice in the great white
  • KennyP and MNGB have said thanks
#4 MNGB OFFLINE
MNGB
  • 2,623 Thanks
  • 1,569 posts
Posted November 23, 2017 - 01:13 PM
Hi jms180, happy thanksgive to you and yours also no white here at this time. :dancingbanana:
  • jms180 said thank you
#5 jms180 ONLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted November 23, 2017 - 02:19 PM
Nice here about 55 and sunshine
#6 MNGB OFFLINE
MNGB
  • 2,623 Thanks
  • 1,569 posts
Posted November 24, 2017 - 08:34 PM
Hi all, worked on fabricating a hitch lift assembly for the PK / snowblower got most of it done will paint tomorrow just have the 2 tie links to fabricate, am waiting for some 1.5"X1/4" x 13" flat stock to make them out of.  Well the carb cleaning helped but the Tecumseh would not run as smooth as it should and would not idle, I had a new aftermarket carb so installed it and the engine started and ran like it was new idles down so now it to change oil and it will be ready.
HPIM1656.JPG HPIM1657.JPG HPIM1658.JPG HPIM1660.JPG HPIM1661.JPG HPIM1662.JPG HPIM1663.JPG HPIM1665.JPG HPIM1659.JPG HPIM1664.JPG
  • grnspot110, Alc, KennyP and 1 other said thanks
#7 MNGB OFFLINE
MNGB
  • 2,623 Thanks
  • 1,569 posts
Posted November 27, 2017 - 07:48 PM
Hi all, the installation of the Haban snowblower on the PK 1614 is for the most part complete finished up installing it on the tractor this afternoon changed oil on the blower engine started it and run the tractor outside the lift works very good have 8.5 inches lift drove the tractor around with the blower up and down and its going to work as intended. Now I need to think about fabricating a cab for the tractor.
HPIM1667.JPG HPIM1668.JPG HPIM1669.JPG HPIM1672.JPG HPIM1673.JPG HPIM1674.JPG
  • grnspot110, Alc, KennyP and 4 others have said thanks
#8 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,837 Thanks
  • 1,582 posts
Posted November 27, 2017 - 09:15 PM
That looks like it ready to move a lot of snow!  Nice job!
#9 Alc ONLINE
  • 7,227 Thanks
  • 7,579 posts
Posted November 28, 2017 - 06:25 AM
Nice job :thumbs:  Kind of amazing that you can lift that snow blower with just that one rod or am I missing something ?  Thinking of the weight , if you have welded 2 piece front hubs check that welds , I had one fail while using mine with the loader . Can't wait for some tests runs in the snow
  • KennyP, MNGB and Mark 149 J. have said thanks
#10 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted November 28, 2017 - 07:02 AM
Looks good on there! Have fun! If not a cab, maybe at least one of these:
https://www.homedepo...80025/202195394
  • MNGB and Mark 149 J. have said thanks
#11 MNGB OFFLINE
MNGB
  • 2,623 Thanks
  • 1,569 posts
Posted November 29, 2017 - 07:39 PM
Hi Alc, it actually lifts very well the rod is 3/4" and is the same as used for the dozer blade and the snowblower that is the about the same unit as this one but without the engine, also I added wt to the drawbar for traction assist and it also has the benefit of counter balancing the blower as the wt goes down as the blower raises and vise versa
#12 MNGB OFFLINE
MNGB
  • 2,623 Thanks
  • 1,569 posts
Posted November 29, 2017 - 07:46 PM
Hi all, today I started work on a cab for the PK will be using the encloser from a Sears cab and am building the frame using PVC 1" tubing. The PVC is easy to work with is strong I used it on a cab for one of the Sears Suburbans and it has worked good, just got a start on it this afternoon.
  • Alc, KennyP and Mark 149 J. have said thanks
#13 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted November 30, 2017 - 06:07 AM
Only thing I would be concerned with on the PVC is it cracking from the vibrations. Hope it works well for you!
Maybe Schedule 80 would be better, thicker wall.
https://screenshots....ipesupplies.com
  • Alc and MNGB have said thanks
#14 MNGB OFFLINE
MNGB
  • 2,623 Thanks
  • 1,569 posts
Posted November 30, 2017 - 01:37 PM
Hi Kenny used it on my Suburban for 3 / 4 yrs at temps of 0*F and no problems the 1" is really tuff stuff, not sure  schedule it is I'll have a look but the wall thickness is about 3/16's" I'm going to use the encloser from the Suburban cab for the PK
Edited by MNGB, November 30, 2017 - 01:40 PM.
#15 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted November 30, 2017 - 04:06 PM
If it's been working that long, then you are good to go!
