What size is a Simplicity Model L engine pulley?
simplicity pulley model l
6 replies to this topic
#1 Greenkeeperherb OFFLINE
Greenkeeperherb
  • 4 Thanks
  • 4 posts
Posted November 22, 2017 - 07:25 PM
   I picked up my tractor about 30 years ago and used it to clear snow off my long driveway and plow the sidewalk. I had a gravel driveway then and the lil' Model L with wheel weights and chains worked better than any snow blower I had tried. (didn't shear pins and throw the gravel everywhere!) I loaned the Model L to my brother-in-law to bulldose out a cellar under his weekend cabin. He  was slow in returning it and by the time he did, I had paved the driveway and gotten a bigger snow blower. The tractor was then  stored away in the bottom of the barn and has been there for the last 15 years.
   Anyway, now my son has a house with a gravel driveway and I'm putting the tractor back in service for him.
   A previous owner changed the engine to a 3 hp Briggs 80200 and instead of the 3-step pulley I believe these tractors are supposed to have on the engine output shaft, he mounted a 2" diameter pulley and a 2 1/2"  diameter pulley back-to-back.
   I would like get the right size 3-step pulley for it, but I don't know what the 3 diameters on the pulley are supposed to be. From photos and parts diagrams I have seen, it looks like it could be a very common 2"-3"-4" step pulley, but I can't be sure.
   Could someone please tell me the three diameters of this pulley?
#2 jimmy G OFFLINE
jimmy G
  • 1,308 Thanks
  • 831 posts
Posted November 22, 2017 - 11:19 PM
I have an M1 that could be correct, if your driven pulleys are same diameter as mine then I would have your measurements, the 3rd pulley is for forward attachments
  • boyscout862 and Greenkeeperherb have said thanks
#3 GWest OFFLINE
GWest
  • 558 Thanks
  • 511 posts
Posted November 23, 2017 - 06:51 AM
From my notes
The D-A13 or 8021013 engine pulley was used on the model D and model L
3/4" ID
2-1/4" and 2-13/16" OD but do not know which 2 grooves were the same.
Garry
#4 boyscout862 ONLINE
  • 13,690 Thanks
  • 9,475 posts
Posted November 23, 2017 - 07:38 AM
Welcome to GTT. Check our Manuals Section for the manuals for your tractor. Post some pics of your L when you get a chance. I put a 5 hp B&S with a 2" pulley on mine because I like the power. Good Luck, Rick
#5 Greenkeeperherb OFFLINE
Greenkeeperherb
  • 4 Thanks
  • 4 posts
Posted November 23, 2017 - 11:46 AM
     Yes, the parts diagram shows the pulley is a Simplicity #DA-13, but I don't think that helps me too much. Unfortunately no dimensions are given.
     They show a different number for the pulley on the model M tractor, but the driven pulley is the same on both. Perhaps the only difference between them is the size of the engine output shafts on the two models. Maybe that"s why the previous owner of my tractor never transferred the old 3-step engine pulley when he rep[aced the original engine with a larger one.
     On my driven pulley (the one on the gearbox that slides), the smaller step is 4 1/2 inches (O.D.) and the larger step is 7 inches (O.D.)
     Many thanks for your help with this.
#6 GWest OFFLINE
GWest
  • 558 Thanks
  • 511 posts
Posted November 24, 2017 - 06:30 AM
The model D and model L shared the same DB-1 or 8022001 transmission pulley unless the 12" tiller was used.
3/4" ID x 4-9/16" and 6-7/8" diameter so we are close.
Garry
  • Greenkeeperherb said thank you
#7 Greenkeeperherb OFFLINE
Greenkeeperherb
  • 4 Thanks
  • 4 posts
Posted December 02, 2017 - 07:25 PM
tractor2.jpg Thanks Gerry for the measurements. I located a pulley at McMaster-Carr that comes very close. Their part number is  #6213K43.  It's for a 3/4" keyed engine shaft and the diameters of the 3 steps are 1 3/4" - 2" - 2 3/4"
I get  4 comfortable speeds using the 2" and 2 3/4" steps on the pulley and the "low-low" gear described in some of the manual by using the smallest step.
Herb Watson
Berlin CT
Also tagged with one or more of these keywords: simplicity, pulley, model l
