FF 24
11 replies to this topic
#1 Macgyver6 OFFLINE
Macgyver6
  • 52 Thanks
  • 12 posts
Posted November 22, 2017 - 06:28 PM
Hello everyone if anyone was watching the CL from the Milwaukee area the FF24 is now in my stable. Kenny your a bad influence cause now I have 2 a FF20 with the loader and this one. Will have to tear down the motor to see what's wrong it's free but only about. 1/2 a turn worst case I drop my back-up 20 in it. I also got a front blade and a spare set of rear wheels with new Goodyear ag tires.
  • olcowhand, KennyP, jimbobbillyray and 3 others have said thanks
#2 KennyP ONLINE
  • 38,374 Thanks
  • 45,931 posts
Posted November 22, 2017 - 06:31 PM
Congrats on the FF24! Hope you can fix the engine!
  • boyscout862, Mark 149 J. and Wnckelsem have said thanks
#3 jms180 ONLINE
jms180
  • 1,517 Thanks
  • 1,567 posts
Posted November 22, 2017 - 06:41 PM
nice find looking forward to some pictures
#4 dodge trucker ONLINE
dodge trucker
  • 2,436 Thanks
  • 3,126 posts
Posted November 23, 2017 - 02:24 PM
I wish I could have gotten ahold of my neighbor's FF24 when he decided he was done with it.
  • KennyP and Wnckelsem have said thanks
#5 Macgyver6 OFFLINE
Macgyver6
  • 52 Thanks
  • 12 posts
Posted December 18, 2017 - 11:00 PM
Well here is an update on the FF24. Sad to say it's now a parts donor. The engine is to far gone and to expensive to repair. With only 630hrs on the hour meter the other parts are in great condition. Except the frame that someone cut to change the starter. I took the steering / front axle out and added Torrington bearings to the spindles hoping to make it steer easier with the loader.
  • Mark 149 J. said thank you
#6 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted December 19, 2017 - 12:17 AM
bring it down here and take one home with you!  I'm always up for a trade!  or, I still have a good running motor out of a FF20 that I would part with....
#7 KennyP ONLINE
  • 38,374 Thanks
  • 45,931 posts
Posted December 19, 2017 - 06:33 AM
Sorry to here the engine is in bad shape. As easy as it is to pull, I can't believe they cut the frame. You just unhook the driveshaft, wiring and throttle/choke cables. Probably the exhaust too. Then 6 bolts along the bottom of the frame to remove the engine and mounting plate. This makes this an easy prospect for a repower as you don't have to worry about a deep sump engine going back in. Can use those 6 holes to build a new mounting system.
#8 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted December 19, 2017 - 02:28 PM
If you decide a repower route, I'd be interested in the P224.
#9 UncleWillie ONLINE
  • 15,671 Thanks
  • 8,763 posts
Posted December 19, 2017 - 04:36 PM
:camera:  :camera:  :picsoritsnotyours:
  • secondtry said thank you
#10 secondtry OFFLINE
secondtry
  • 1,901 Thanks
  • 1,387 posts
Posted December 19, 2017 - 06:32 PM
What he said. Don
#11 Macgyver6 OFFLINE
Macgyver6
  • 52 Thanks
  • 12 posts
Posted December 19, 2017 - 08:37 PM
Ok what do you want pics of the front axle that I put the bearings on the spindles?
#12 secondtry OFFLINE
secondtry
  • 1,901 Thanks
  • 1,387 posts
Posted December 25, 2017 - 01:22 AM
   That will work, is it the same axle as the 18/6? Was the modification successful in improving the steering? My 18/6 with loader is relatively easy to steer with 6 40lb bags of wood pellets in the bucket. Don
