Jacobson Super Chief 1450 not throwing snow
13 replies to this topic
#1 ResOps OFFLINE
ResOps
  • 10 Thanks
  • 10 posts
Posted November 22, 2017 - 05:23 AM
As the post says my super chief 1450 is only spitting snow. This isn't wet snow but not super fluffy. I though I read somewhere that there were 2 different pulleys (size) used for mower / snowblower. Am I expecting too much from the single stage blower. Help would be appreciated to a nooby Jake owner
#2 EricFromPa ONLINE
EricFromPa
  • 3,384 Thanks
  • 3,015 posts
Posted November 22, 2017 - 06:07 AM
How much snow? Single stage blowers don't work very well with anything under about 6 inches and you have to feed them faster than a dual stage. Try moving a little faster and see if that helps.
#3 poncho62 ONLINE
poncho62
  • 1,422 Thanks
  • 1,554 posts
Posted November 22, 2017 - 06:24 AM
Also, check and see how much space is between the auger and the blower housing.....Mine were all bent up and had a large space. I added pieces of rubber belting to take up the space.....Haven't tried it yet but will see is it improves.
BTW...the blower belt should be on the larger pulley of the PTO clutch
#4 ResOps OFFLINE
ResOps
  • 10 Thanks
  • 10 posts
Posted November 22, 2017 - 06:55 AM
I'm moving fairly fast and full throttle- bout 4" snow and it's choking the chute constantly.
#5 ResOps OFFLINE
ResOps
  • 10 Thanks
  • 10 posts
Posted November 22, 2017 - 07:03 AM
I'm not sure there are two pulleys-you mean at the electric clutch? And 2 is the drum adjustable?to the back wall I mean.Oh I'm new to this ;)
#6 poncho62 ONLINE
poncho62
  • 1,422 Thanks
  • 1,554 posts
Posted November 22, 2017 - 07:17 AM
No adjustment that I could see....
Yes, larger pulley at the clutch....mine has 2, yours may not
  • boyscout862 and ResOps have said thanks
#7 Doug E. ONLINE
Doug E.
  • 294 Thanks
  • 159 posts
Posted November 22, 2017 - 08:38 AM
I did like Poncho62 did with the bailer belting on my single stage Bolens snowblowers, and rarely have the chute clog, even on slush.  Width wise, I cut the belting wider so that it starts to wrap around the corners of the paddles, left and right.  Not sure how much difference this makes, since I didn't try it narrower, but suspect it helps by not allowing the snow or slush to fall off of the sides of the paddles.  I cut it a little long and trimmed it to length with a sharp knife, allowing about 1/16th of clearance between the auger housing.   I can go through a slushy puddle now and it will blow the slush and water but not clog up the chute.  On one blower, the paddles were quite damaged, and I bolted some 1/8 steel plates underneath the belting to back them up as a stop gap measure.  That blower would hardly work with out clogging without adding the mods.
Regards,
Doug
#8 boyscout862 ONLINE
  • 12,177 Thanks
  • 8,893 posts
Posted November 22, 2017 - 09:37 AM
Go to our Manuals Section and look for the original blower manual. See what it says. It makes sense that you need to be on the larger pulley at the PTO. If you are still having problems, post some clear picks of the blower, tractor, PTO, and the routes that the belts follow. Good  Luck, Rick
  • propane1 and ResOps have said thanks
#9 ResOps OFFLINE
ResOps
  • 10 Thanks
  • 10 posts
Posted November 23, 2017 - 06:33 AM
TX Boyscout,
With the cooler weather yesterday the snow  hardened up a bit and I re-belted the blower. You know what I threw snow "like the wind" to quote Forrest Gump.
I will take some pics today but it appears I only have one pulley in the electric clutch housing. I'm sure the belt is routed right.
#10 pryan05 ONLINE
pryan05
    LGT
  • 596 Thanks
  • 330 posts
Posted November 23, 2017 - 07:10 PM
Lets us know how that works, please.
#11 ResOps OFFLINE
ResOps
  • 10 Thanks
  • 10 posts
Posted December 09, 2017 - 06:24 AM
Well I must admit the paddle was worn alot. I used a mud flap and cut two paddle extensions and boy what a difference they are crewd- the next ones will be rounded .
  • olcowhand said thank you
#12 poncho62 ONLINE
poncho62
  • 1,422 Thanks
  • 1,554 posts
Posted December 09, 2017 - 06:32 AM
We got some snow yesterday, I will be trying mine out today.
#13 poncho62 ONLINE
poncho62
  • 1,422 Thanks
  • 1,554 posts
Posted December 09, 2017 - 09:18 AM
Blew back a couple of snow banks this morning, with the rubber belting, works 100% better than last year
  • olcowhand and pryan05 have said thanks
#14 pryan05 ONLINE
pryan05
    LGT
  • 596 Thanks
  • 330 posts
Posted December 09, 2017 - 03:18 PM
I'll have to try that on my single stage.  I simple installation that adds trowing distance.  Thanks Poncho!
