Converted a Spring tooth digger to 3 pt
8 replies to this topic
#1 MNGB OFFLINE
MNGB
  • 5323 Thanks
  • 2588 posts
Posted November 21, 2017 - 07:35 PM
Hi all, just finished up on converting an old pull type spring tooth digger to 3 pt hitch to use behind the Power King, I like these digger for garden work they do a good job and leave the ground in nice shape. I've been watching on CL's for a couple of years for one here in MN the cheap worn busted up ones are priced at $50.00 plus and half decent ones for $75 to $100.00 \have even seen them at $200.00. Well in mid Oct there was a farm auction less then 10 mile from me and it had one on it and in very good condition so I went and stood around for 2/3 hrs and the auctioneer finally got to it of course they tried getting a opening bid of $50.00 after a bit I said $10.00 and that was the first and last bid so I got it for 10. So after I  finished the JD LA got to work and fabricated a 3 pt hitch for it, if I were to do it over I'd use a different type of hitch but this one will be good.
HPIM1644.JPG HPIM1645.JPG HPIM1648.JPG HPIM1651.JPG HPIM1652.JPG HPIM1653.JPG
Edited by MNGB, November 21, 2017 - 10:19 PM.
  • Gtractor, KennyP, CRFarnsworth and 4 others have said thanks
#2 lyall OFFLINE
lyall
  • 2459 Thanks
  • 1722 posts
Posted November 21, 2017 - 09:05 PM
have fun with it in the garden
it should work good for many more years
  • boyscout862 and MNGB have said thanks
#3 Leonard VanCamp OFFLINE
Leonard VanCamp
    Deere Herder
  • 1065 Thanks
  • 674 posts
Posted November 21, 2017 - 09:14 PM
My uncle made a small version from a section of a large harrow, used it behind his Sears SS14, worked good for over 40 years.
  • MNGB said thank you
#4 coxhaus OFFLINE
coxhaus
  • 346 Thanks
  • 278 posts
Posted November 21, 2017 - 10:37 PM
How would you have done the hitch different?
  • KennyP and MNGB have said thanks
#5 MNGB OFFLINE
MNGB
  • 5323 Thanks
  • 2588 posts
Posted November 21, 2017 - 10:43 PM
Hi, I would have hinged the 3 pt at the lower point and used chains going to the aft tooth bar that way the chains would lift the rear but when on the ground they would alow the digger to float, I now have float using the flex top link mount.
  • Gtractor and KennyP have said thanks
#6 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted November 22, 2017 - 05:13 AM
Nice! Should work well for you!
#7 shorty OFFLINE
shorty
  • 6033 Thanks
  • 5507 posts
Posted November 22, 2017 - 08:14 PM
Nice way of making it hook up. What is the working depth of one like this?
#8 MNGB OFFLINE
MNGB
  • 5323 Thanks
  • 2588 posts
Posted November 22, 2017 - 08:23 PM
Hi shorty, I think 4 maybe 5 inches, yesterday I took it outside for winter starage and thought I'd see if it would go in the ground but no way the ground is frozen so I'll have to wait till spring to try it and report back, I think probably more then the Power King can pull.
  • shorty said thank you
#9 Leonard VanCamp OFFLINE
Leonard VanCamp
    Deere Herder
  • 1065 Thanks
  • 674 posts
Posted November 22, 2017 - 08:41 PM
You sink them all the way down and they'll give that PK a good workout if not stall it. My uncle had to hook his Allis Chalmers WC to his when he sunk them all the way in. You have to have pretty loose ground to get full depth. The real benefit to them is they tend to pull rocks to the surface making it easy to pick them.
Edited by Leonard VanCamp, November 22, 2017 - 08:43 PM.
