mf10 BandS swap
#1
OFFLINE
Posted November 20, 2017 - 01:58 AM
thanks for any help
lloyd
- DMAX, MFDAC, propane1 and 1 other said thanks
#2
OFFLINE
Posted November 20, 2017 - 07:30 AM
You may have to get a little bit larger of a belt, these belts are not made to stretch. Before you do that though maybe someone who knows masseys will chime in and help you with how the belt is adjusted on those machines. I have never had my hands on a massey so I don't know, but many have idler pulleys that can be adjusted, seeing that things have changed your most likely will be looking at a new belt.
- boyscout862 said thank you
#3
ONLINE
Posted November 20, 2017 - 09:40 AM
Welcome to GTT. Play with the MF7 and search for an engine for the MF10. Engines pop up every where if you talk to friends and family about your search. I acquired several engines at our town transfer station just this year and a couple of more at swap meets. I don't pay much for used engines because they can't prove that they work(and usually don't). The engine for your MF10 is risky because those ignition systems are fragile and expensive. One engine that I picked out of the scrap pile, I wanted because there was a chance that the ignition module was still good. You will want the extra horse power for the tiller. Don't forget to download the manuals that you need from our Manuals Section(3 for free per day). Good Luck, Rick
Edited by boyscout862, November 20, 2017 - 09:41 AM.
- MolonLabe said thank you
#4
OFFLINE
Posted November 20, 2017 - 11:14 AM
#5
OFFLINE
Posted November 20, 2017 - 03:11 PM
#6
OFFLINE
Posted November 20, 2017 - 05:11 PM
- boyscout862 and propane1 have said thanks
#7
OFFLINE
Posted November 22, 2017 - 03:11 AM
#8
OFFLINE
Posted November 22, 2017 - 09:43 PM
I have a 3 belt pulley on the Briggs 8hp but as I understand that won't work. I read somewhere that a Honda gx390 may work. Any thoughts?
Hi Lloyd, although not real popular among most tractor guys, I did a GX390 CLONE swap on my MF12G two years ago. It's been running great mowing and pushing snow. This was not a direct bolt in swap though. Mine is a gear drive (Vari-Speed) and yours must be a Hydro. DH1 did this swap on a few hydros. If you want something to swap pretty easy though, Esbbent is right about sticking with a Tecumseh, if you can find one in good shape.
Good luck and welcome to the forum!
DAC
#9
OFFLINE
Posted November 25, 2017 - 12:35 PM
How about a Kohler 14 magnum? would that work as far as power? also, I'm new to all this. is the idea just finding an engine with proper torque and power and then fitting it in is a matter of adjusting pulleys and belt sizes. also electric start of course is handy
#10
OFFLINE
Posted November 25, 2017 - 12:39 PM
#11
OFFLINE
Posted November 26, 2017 - 01:47 AM
#12
OFFLINE
Posted December 01, 2017 - 02:44 PM
#13
OFFLINE
Posted December 05, 2017 - 12:18 AM
can someone give me some direction for pulleys?
#14
ONLINE
Posted December 05, 2017 - 05:21 AM
I know nothing about Massey's, but maybe this parts manual will help. Page 12 shows the main drive pulley, part # 511 140 M2. Looks like a stack of 3 pulleys, have no idea of diameter.
- boyscout862 and lloydmf10 have said thanks
#15
ONLINE
Posted December 05, 2017 - 08:47 AM
I have swapped engines in some tractors successfully but some required alot of work. Try test fitting what you have to see how they fit. Many times the bolt patterns are the same. As far as horse power, 10 hp is probably be adequate for most work. A 12 hp is better for snow blowers and tillers. The 8 hp B&S should be fine for plowing or mowing. Part of what you are going to do is going to require some trial and error. For safety, never just set the engine on the frame. Bolt it down so that it can't fall. Post some pics of the tractors, engines, and the test fits. The footer of Kenny's postings has instructions on how to post pics. You are building a nice herd. Good Luck, Rick
- DMAX, MFDAC and lloydmf10 have said thanks
