Ariens GT17 Not Charging
5 replies to this topic
#1 arniearni OFFLINE
arniearni
  • 2 Thanks
  • 4 posts
Posted November 19, 2017 - 09:14 PM
When running I have 12.45 volts at battery which slowly increases by about .01 volt in about 5 minutes. New Battery, New Voltage Regulator. I have 30 volts ac on ac terminals of voltage regulator. With engine off and ignition key on I have 12 volts dc between center terminal of voltage regulator and ground. So it appears Ignition Switch is Good, wiring between battery and voltage regulator is good I have tried 3 different regulators (one brand new) all with the same result. What am I missing??? The engine is a kohler magnum 18hp (must have been replaced at some point in its life).
#2 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted November 20, 2017 - 06:36 AM
Welcome to GTTalk !   You have a good stumper there lol . Not what I would do next , did you check that the regulator has a good ground where it mounts ? From  what you posted I believe you already did and since you changed it more then once it should be good . Did you remove the a/c wires to test or did you check that it had 30 volts right on the regulator spades ?  I'm sure others will be more helpful , good luck
  • boyscout862 and arniearni have said thanks
#3 dodge trucker ONLINE
dodge trucker
  • 2,413 Thanks
  • 3,110 posts
Posted November 20, 2017 - 07:19 AM
check connector terminals for corrosion.  and that connector is all the way seated on regulator. just ran into that yesterday as I finished up a complete rewire of a S-16H with a Kohler single. I had to slightly pry the connector onto the regulator to get it to seat.
#4 boyscout862 ONLINE
  • 12,818 Thanks
  • 9,153 posts
Posted November 20, 2017 - 09:32 AM
Welcome to GTT. Check in our Manuals Section(3 free downloads per day) for the engine manual and see what the Troubleshooting Guide tells. Good Luck, Rick
  • arniearni said thank you
#5 arniearni OFFLINE
arniearni
  • 2 Thanks
  • 4 posts
Posted November 20, 2017 - 06:24 PM
Thanks for the replies. I think this weekend I will run a wire from dc voltage terminal on regulator to positive battery terminal and another wire from regulator mounting bolt to negative battery terminal and see what I get. That should tell me if there is an issue somewhere or maybe that's all I'm going to get out of my regulator with the ac supplied.
#6 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted November 21, 2017 - 07:40 AM
Remember to rev the engine as it does not charge much at idle!
