Power Steering Conversion
9 replies to this topic
#1 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted November 19, 2017 - 08:52 AM
Looking at putting a power steering unit on my 1512.    I have pulled and rebuilt the power steering on a super cub.  Are there other units that will fit in the 1512 or does it have to come from another cub?  I know a JD cylinder will fit OK.
#2 jms180 OFFLINE
jms180
  • 1,511 Thanks
  • 1,564 posts
Posted November 19, 2017 - 10:04 AM
i have a John Deere cylinder from a F910 if you need
  • chieffan said thank you
#3 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted November 19, 2017 - 01:54 PM
Will sure keep that in mind.  Haven't rounded up any of the components as yet.
Sorry for the double post - don't know what happened.  Mod can delete the first one if they want/would.
#4 Oak OFFLINE
Oak
  • 46 Thanks
  • 46 posts
Posted November 20, 2017 - 09:15 PM
There was a guy that did one on OCC on an 1811 that should be pretty much the same. He did have a few minor issues.  I guess you can't post a link to another site or I would.
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted November 20, 2017 - 09:46 PM
You go ahead and post that link, Oak. Totally within the rules to link outside if the info can't be found here.
#6 Oak OFFLINE
Oak
  • 46 Thanks
  • 46 posts
Posted November 21, 2017 - 06:52 AM
It won't let me post a link. :(
#7 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted November 21, 2017 - 08:16 AM
Thanks to member 'Oak' I found the thread at OCC and here is the link.
  • Alc and Mark 149 J. have said thanks
#8 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted December 18, 2017 - 04:12 PM
I have gave up completely on OCC.  Can never get signed in.  Have set up 3 different accounts.  All been approved but none will let me sign in so gave it up as a bad venture.
Thanks for that link Kenny.  I FINALLY got far enough to read all the posts but could not open any pictures.  I think that may be more of a project than what I want to get in to.   Not that big a deal to steer it with a knob on the wheel.  If I have to will hang a couple hundred lbs off the back a ways to lighten up the front end a little. :thumbs:
Edited by chieffan, December 18, 2017 - 04:36 PM.
#9 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted December 18, 2017 - 04:26 PM
Must be something on your end cause I have no issue over on OCC.
#10 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted December 24, 2017 - 09:48 PM
Been a long time since i've posted, I've been gathering parts for a year to add power steering to my 1512. I am using a JD 300 series column. The steering cylinder and mounts and knuckle from an 1864. As for mounting the JD column in the Cub a member over on OCC sent me detailed pictures of how he did is and i am doing it in the same way. My only recommendation if you plan on doing this is to convert to a CV style drive shaft and it free's up room near the column.  When i get my tax return i am going to get the adapters made and my CV shaft shortened and i'm going to do the CV shaft conversion and convert to PS in one shot.
  • Alc, KennyP and Mark 149 J. have said thanks
