582 questions
6 replies to this topic
#1 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted November 15, 2017 - 07:22 PM
Picked up a 582 cub, very nice overall but noticed when I unloaded it, it rolls when in gear (any gear) gotta tear into the tranny this week. any idea what might make it do this ?
  • Mark 149 J. said thank you
#2 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted November 15, 2017 - 09:14 PM
Does it run and drive? How about just looking at driveshaft couplings or clutch first? Start with small stuff.
  • KennyP, Dayton_King and Mark 149 J. have said thanks
#3 Dayton_King ONLINE
Dayton_King
  • 1,245 Thanks
  • 1,049 posts
Posted November 15, 2017 - 09:24 PM
Or the drive shaft is not connected. Before tearing a trans apart check it over
  • KennyP and Mark 149 J. have said thanks
#4 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted November 16, 2017 - 11:29 AM
If it will roll in any gear then it must be a driveshaft issue. Pull the tunnel cover and check the spiral pins in the driveshaft, it's not uncommon for them to break after all these years. The pins are special and you can't just put a roll pin in it or it will break.
#5 the summoner OFFLINE
the summoner
  • 8 posts
Posted November 26, 2017 - 06:57 PM
What Tim said, I am sure it is difficult to move, but if it rolls like it is in neutral, there may be an internal transmission issue.
Is it red, or yellow and white?
#6 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted November 29, 2017 - 08:53 AM
Red model 582 rolls really easy in any gear, haven’t had a chance to look at it yet. But thanks to all for the info
#7 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted November 29, 2017 - 09:25 AM
Are you sure it is going in gear?
