Looks like a B to me, more pics will help, ser. No.s off engine and gear case (behind wheel) will correctly date it, just looking I'm thinking 43-47, i think the D is 48-49 with multiple speeds, the tool bar looks to be later, the tool guide looks correct, agree with sod cutter
With out the later attachment mounts this tool bar would be correct, pic is of a 47, at least 6 brands ran interchangeable like attachments in this line (not counting export), the 43 would have been styled so I'm at 44-47 for year made with out no's
Top two are, type (left) ser no. (Right), bottom two are valve clearance, intake and exhaust, look for 1 1/2 hp. Briggs and Stratton ser. No's between 44-47 (the B&S site for this is a quick hit), this also could be the ward's version (Hoe-Trac) 44-46, ward's had their own tag and no's on engine's it used, the ser. no on gear case was shared by Simplicity and wards. Had to edit cus i messed up the top no's (corrected), the model no. is missing but should be a N, ser.no. indicate's Dec. 45 which makes your tractor a 46, the I.D plate is screwed on which leads me to believe it's a Hoe-Trac
not the knobby, AG treads are out there, somtimes you can find good used ones, you can post in the wanted forum on this site also, eather way you go if you have a problem sourcing parts you can ask the members for recamendations, i keep an eye out for used myself
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
