Was the 1476 lighter than a normal large frame?
10 replies to this topic
#1 Mustard Tiger ONLINE
Mustard Tiger
  • 93 Thanks
  • 117 posts
Posted November 13, 2017 - 11:46 PM
Tractordata.com has it listed at only 860 pounds, while the other large frames are 100+ pounds heavier. Does anyone know for sure if that's a mistake or if they really were lighter? I'm looking for something heavy but cheap to put a FEL on.
#2 fonz3482 OFFLINE
fonz3482
  • 1,325 Thanks
  • 783 posts
Posted November 14, 2017 - 04:26 AM
That does seem light for a large frame, but I'm not sure if it is right or wrong. The difference in weight you are asking about between the 1476 and the rest of the large frame lineup is probably just from a different and bigger engine that the other LF use. The 1476 is a single cylinder engine and the 1886-HT23 run the kohler twin cylinder engine.. I'm sure there is a few other differences that may add weight to the higher HP large frames, but I'm not that well versed in them. I think the tractor itself will be fine to handle a FEL because the smaller 1250 could run a FEL.  Hopefully I'm helping out, but I'm sure the LF guys will chime in to help you answer your question better
  • blackjackjakexxix and Austen have said thanks
#3 Husky ONLINE
Husky
  • 1,250 Thanks
  • 1,109 posts
Posted November 14, 2017 - 07:34 AM
Shipping weight is 975 pounds according to the 1476 user manual.
  • blackjackjakexxix and Mustard Tiger have said thanks
#4 Mustard Tiger ONLINE
Mustard Tiger
  • 93 Thanks
  • 117 posts
Posted November 14, 2017 - 08:43 AM
That's just the tractor without the deck right?
#5 firedudetl1 ONLINE
firedudetl1
  • 118 Thanks
  • 105 posts
Posted November 14, 2017 - 10:00 AM
for what's it worth, I have a 1477 with a S14D single cylinder wisconsin with a Johnson front end loader and it seems "fine" - I did add about 150 cement weight at the back but the machine seems to handle the FEL without any problems
#6 Husky ONLINE
Husky
  • 1,250 Thanks
  • 1,109 posts
Posted November 14, 2017 - 10:05 AM
Correct, 975 as shipped no attachments on board. If you search our manuals section you can find the owner manual. If you can't find it send me a PM with your email address and I can send you the manuals on it.
#7 Bud W ONLINE
Bud W
  • 315 Thanks
  • 298 posts
Posted November 14, 2017 - 12:15 PM
My friend had a 1476 that has a Briggs 18 hp twin with a Johnson 10 midget loader on it. It also has two 1962 Ford Econoline weight plates on the back.  It is very strong and can lift a lot.
#8 Husky ONLINE
Husky
  • 1,250 Thanks
  • 1,109 posts
Posted November 14, 2017 - 01:04 PM
1455,76,77 all great tractors for sure. The loaders are great too.
#9 wilberj OFFLINE
wilberj
  • 4,991 Thanks
  • 5,590 posts
Posted November 14, 2017 - 04:34 PM
I wouldent trust Tractordata.com for most of my info...
Ed has the weight right.
#10 Bigdaddydon OFFLINE
Bigdaddydon
  • 76 Thanks
  • 232 posts
Posted November 14, 2017 - 06:05 PM
Bit of a tangent.  Is the seat /fender pan the same on the 1476 and the 1886?
#11 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted November 18, 2017 - 03:39 AM
It is a functional equivalent.
The 1476 has a deck height indicator that the 1886 does not.
I believe that may have made a slight difference.
Joe
