SS15 Teardown
37 replies to this topic
#31 bbuckler ONLINE
bbuckler
  • 3,808 Thanks
  • 3,311 posts
Posted March 05, 2018 - 09:48 AM
There is definitely water in that!
After 3 flushings there was still some in there
  • GTpicker01 said thank you
#32 bbuckler ONLINE
bbuckler
  • 3,808 Thanks
  • 3,311 posts
Posted March 07, 2018 - 06:58 PM
One of the new axle seals got a slow leak so I can I need to replace it again. Maybe wait until I change the oil again after running it .
  • John Arsenault said thank you
#33 John Arsenault OFFLINE
John Arsenault
  • 3,032 Thanks
  • 1,364 posts
Posted March 08, 2018 - 07:28 AM
New seal? maybe it has a piece of debris in it? I have cleaned debris out of seals before using a business card. You fold the card over the axle  and insert it in between the axle and oil seal and rotate it around. That will often clear the debris and stop the leak. If the seal got torn from installing it then it won't help any.
  • bbuckler said thank you
#34 bbuckler ONLINE
bbuckler
  • 3,808 Thanks
  • 3,311 posts
Posted March 11, 2018 - 03:19 PM
Got one of the front tires on but it looking like I'm going to need to get some starting fluid to finish the other one. Rear tires are getting the tubes put in next.
#35 bbuckler ONLINE
bbuckler
  • 3,808 Thanks
  • 3,311 posts
Posted March 11, 2018 - 06:30 PM
Front tires finished. I got these for $25 each on Amazon.
  • KennyP, GTpicker01 and Jazz have said thanks
#36 bbuckler ONLINE
bbuckler
  • 3,808 Thanks
  • 3,311 posts
Posted March 12, 2018 - 05:55 PM
Done other then the hood and brake band which I will do later on.
  • KennyP, GTpicker01 and John Arsenault have said thanks
#37 bbuckler ONLINE
bbuckler
  • 3,808 Thanks
  • 3,311 posts
Posted March 16, 2018 - 08:40 PM
Still leaking a little so I ordered another new seal since I got to change the fluid again anyways.
#38 Jazz ONLINE
Jazz
  • 2,710 Thanks
  • 1,567 posts
Posted March 22, 2018 - 01:27 PM
Here is the fluid coming out yesterday
That's definitely water. If tractor had been allowed to set a while the water would have separated and settled to bottom. With boat motors we see clear water come out ahead of the oil if motor has set a while.  Some weird lumps coming out as well.  Could use a shot of penicillin. :D
Edited by Jazz, March 22, 2018 - 01:29 PM.
