SS15 Teardown
37 replies to this topic
#16 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted January 17, 2018 - 09:13 PM
Axle seals are in. I got to looking at all I need to do now and I'm still need $220 to finish this tractor.
#17 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted January 21, 2018 - 06:45 PM
Sold the mower I had and ordered new front tires , rear tire tubes , voltage regulator and choke cable.
I still need new battery , oil for the transaxle and the engine , wire , battery cables , drive belt  and oil pan gasket.
Edited by bbuckler, January 21, 2018 - 06:45 PM.
#18 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted January 25, 2018 - 10:52 PM
Just need oil and a belt now
  • GTpicker01 and John Arsenault have said thanks
#19 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted February 14, 2018 - 10:51 PM
Wiring is finished time to install the engine. I got to change the tires soon.
  • GTpicker01 said thank you
#20 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted February 20, 2018 - 08:27 PM
I got one front tire off after fighting with it awhile but now I got another one that just won't budge even when we used the wheelift on the tow truck.
#21 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 744 Thanks
  • 617 posts
Posted February 21, 2018 - 09:45 AM
Just found this thread. Always wanted an SS15. Excited to see the final product. If you have trouble with tires, try a mini tire changer from harbor freight. Works good on small front tires like this, but don't try anything bigger.
  • bbuckler said thank you
#22 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted February 21, 2018 - 10:06 AM
Got one but they don't work good with tires that are stuck on from rust or fix a flat.
#23 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 744 Thanks
  • 617 posts
Posted February 21, 2018 - 10:09 AM
No they don't. I have one of the larger tire changers too and that has a bead breaker on it that helps a lot for things like that.
#24 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted February 21, 2018 - 12:56 PM
They work great installing
#25 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted February 27, 2018 - 10:16 AM
I got the belts in and I started putting the tractor back together. I need to run to tractor supply to pick of some bolts it missing some.
#26 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted March 01, 2018 - 09:41 AM
Can't afford to fix the Starter/Generator yet so I'm going to put it back together for now and pull start it.
#27 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted March 03, 2018 - 11:52 AM
I'm working on getting the seized drain plug out of the transaxle. I fixed the S/G with a bolt and a cable in probably not a permanent fixed but as long as it get be thru the start of the growing season. Other then the drain plug and tires I got it put back together.
#28 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted March 03, 2018 - 08:19 PM
I flushed the transaxle with diesel and still couldn't get it all cleaned out so I added fresh oil and going to change it out after a hour or so of use. I will post the video later of the crud that came out of it.
#29 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted March 04, 2018 - 03:33 PM
Here is the fluid coming out yesterday
  • Jazz said thank you
#30 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 744 Thanks
  • 617 posts
Posted March 05, 2018 - 09:30 AM
There is definitely water in that!
  • bbuckler and Jazz have said thanks
