Brinly Plow Differences
9 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,685 Thanks
  • 1,886 posts
Posted November 12, 2017 - 10:35 PM
Here's something I noticed today. I have 3 Brinly 12" 3 point plows. The 2 original white plows are the same. Anyone notice the difference in beam angle on the green which was an original black plow. I always thought the black pulled different. Haven't looked super close yet since they're both still dirty from today's activities. I plan to do some work on them and see where this difference actually is. The 3 point adapter on the green one sits a couple inches lower and angles down more.20171112_215317.jpg 20171112_215325.jpg 20171112_215331.jpg
  • KennyP, CRFarnsworth, boyscout862 and 2 others have said thanks
#2 Randy4S OFFLINE
Randy4S
  • 1 Thanks
  • 3 posts
Posted November 12, 2017 - 10:44 PM
Wish I could find one
  • kjmweld said thank you
#3 kjmweld ONLINE
kjmweld
  • 477 Thanks
  • 344 posts
Posted November 13, 2017 - 04:26 AM
I have a brinly 3 point hitch plow I'd sell. If interested, let me know. I'm in Central Square NY.
  • limebuzz said thank you
#4 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted November 13, 2017 - 05:42 AM
That green one would need a totally different set up to work. Be interesting to see exactly where the difference is in the beams.
  • dropped82 said thank you
#5 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted November 13, 2017 - 08:42 AM
Sets like sleeve hitch. If someone has both can tell you if sleeve beam is more arced.
#6 dropped82 ONLINE
dropped82
    Nut Case
  • 2,685 Thanks
  • 1,886 posts
Posted November 13, 2017 - 09:17 AM
I have sleeve hitch plows also. The beams on those are noticeably thinner. I'll take a pic when I get home
#7 case442 ONLINE
case442
  • 694 Thanks
  • 424 posts
Posted November 13, 2017 - 01:21 PM
Could the green one be Ohio Steel?
Mike
#8 dropped82 ONLINE
dropped82
    Nut Case
  • 2,685 Thanks
  • 1,886 posts
Posted November 13, 2017 - 01:37 PM
Mike
It's definitely a Brinly.
#9 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted November 13, 2017 - 01:59 PM
If the arc is same likely soft bolts bent or sheared from to much down pressure.
#10 Littledeere OFFLINE
Littledeere
  • 1,651 Thanks
  • 1,484 posts
Posted November 13, 2017 - 06:42 PM
I can tell you that there where different ones built looking from the back does the adapted look the same were the brace comes down.
