* * * * * 1 votes
My GK
bolens grounds keeper gk960
84 replies to this topic
#61 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 01, 2018 - 08:30 PM
(3) 1-1/2” bolt locations
All bolts installed and torqued
  • KennyP, 29 Chev, logmillingman and 1 other said thanks
#62 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 01, 2018 - 08:43 PM
PTO vs engine RPM test
PTO RPM = 680 ish @ 2000 rpm (max engine torque according to manuals)
PTO RPM = 840 ish @ 2500 engine RPM
PTO RPM = 1000 ish @ 3000 engine RPM
Max 18.0 hp @ 3200 engine RPM (per manual)
Max RPM = 3600 (per manual)
All vids on YouTube soon.
Edited by Philgk, February 01, 2018 - 08:46 PM.
  • logmillingman, jpswift1 and Corvairguy have said thanks
#63 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,358 Thanks
  • 1,332 posts
Posted February 01, 2018 - 11:01 PM
Already looking a lot better!
Has anybody suggested making sure the head is good and flat using a thick piece of glass and some wet sanding paper?  It's not too late if you haven't.
Edited by Mark 149 J., February 02, 2018 - 10:25 AM.
  • logmillingman said thank you
#64 logmillingman ONLINE
logmillingman
  • 600 Thanks
  • 319 posts
Posted February 02, 2018 - 09:33 AM
Looking nice,keep up the good work!
#65 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 04, 2018 - 08:50 PM
I finally opened up my magnito on my THD.  It didn't look too bad.  I filed the points, turned the cam wiper around to a fresh side and adjusted the gap (.015").  Seems to run quite a bit smoother.  I will probably replace the guts of the magnito this summer just to have a fresh start.  Pictures show magnito inerts before, worn points, clean points and magnito inerts after.
Edited by Philgk, February 04, 2018 - 09:05 PM.
  • Leonard VanCamp, logmillingman, jpswift1 and 1 other said thanks
#66 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 04, 2018 - 09:08 PM
While I was cleaning the head on my THD I notice these funny marks.  Does anyone know what would have made them?  They are just on the one side.  Did something get dropped in that cylinder through the spark plug hole and get run?
Thanks
Edited by Philgk, February 04, 2018 - 09:17 PM.
  • logmillingman and Mark 149 J. have said thanks
#67 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 04, 2018 - 09:12 PM
Dirty block and head, then clean.
#68 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 04, 2018 - 09:15 PM
All videos on YouTube.  I had to remove all videos from here because they suck up too much space.  If anyone has a question or wants to see something in particular please feel free to ask.  Just trying to share info that might be useful to some.  I plan on documenting the RPM of the snowcaster parts at 1000 RPM in the future to see if I can improve its performance.
Edited by Philgk, February 04, 2018 - 09:16 PM.
  • logmillingman and jpswift1 have said thanks
#69 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,358 Thanks
  • 1,332 posts
Posted February 04, 2018 - 11:20 PM
Thanks
That's what it looks like to me.
#70 Luigi OFFLINE
Luigi
  • 17 Thanks
  • 15 posts
Posted February 10, 2018 - 11:33 AM
Funny that there are not corresponding marks on the piston. I would guess that those are voids in the casting. There is one at about 5 o'clock that is under the sealing ring of the gasket.
  • Mark 149 J. said thank you
#71 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 10, 2018 - 03:16 PM
New vids on Youtube.  Snowblowing
  • 29 Chev and jpswift1 have said thanks
#72 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 10, 2018 - 03:17 PM
I see that now.  That is funny.  They almost look like someone pounded on it or something.  But could be voids.  Thanks for the input.
#73 KennyP ONLINE
  • 38,336 Thanks
  • 45,913 posts
Posted February 10, 2018 - 03:21 PM
Could be the head is off another engine or the piston was changed out!
#74 Philgk ONLINE
Philgk
  • 141 Thanks
  • 56 posts
Posted February 10, 2018 - 03:49 PM
Good point.
#75 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,662 Thanks
  • 2,852 posts
Posted February 10, 2018 - 04:45 PM
Thanks for the video.  It doesn't seem to matter when you blow snow there is always a vehicle in the way - even if it is your own.
  • Clevis said thank you
Also tagged with one or more of these keywords: bolens, grounds keeper, gk960
