carbs question
1 reply to this topic
#1 lrhredjb OFFLINE
lrhredjb
  • 695 Thanks
  • 569 posts
Posted November 10, 2017 - 10:09 AM
Whats the difference between 2 stroke carbs and 4 stroke carbs? I got a couple of 2 stroke carbs laying around that look a lot different from others I have. They don't seem to have any float bowl on them. I got them in a bunch of motorcycle stuff.
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,994 posts
Posted November 10, 2017 - 11:20 AM
The carbs without a float bowl most likely are diaphragm carbs that work from crankcase pulse pressure. Either engine could use either style carb as long as the spacing and connections are right. An example would be the Briggs pulse-jet carb. It doesn't have the float bowl and is still used on a 4 stoke engine. Early 2 strokes used float bowl carbs also.
  • Bolens 1000 and lrhredjb have said thanks
