lgt 165 pivot grease zerk
3 replies to this topic
#1 plowmaster54 OFFLINE
plowmaster54
  • 9 Thanks
  • 7 posts
Posted November 09, 2017 - 02:50 PM
Scratching my head on this----Is there supposed to be a grease zerk for the front axle pivot pin? There is a square headed bolt that threads in from the bottom in the area where I assume a grease zerk should be. I've looked at the parts list and do not find a zerk listed for the axle pivot. Also in the operators manual no mention of a grease fitting in this area.
 If the pivot is not supposed to be greased, then does the bolt have a purpose?
Thanks
David
#2 KennyP ONLINE
  • 38,304 Thanks
  • 45,899 posts
Posted November 09, 2017 - 05:46 PM
I haven't seen one with a zerk up there!
  • plowmaster54 said thank you
#3 poncho62 ONLINE
poncho62
  • 1,734 Thanks
  • 1,662 posts
Posted November 09, 2017 - 05:59 PM
My LGTs also have that square headed bolt. I imagine its there to hold the pin in place
#4 plowmaster54 OFFLINE
plowmaster54
  • 9 Thanks
  • 7 posts
Posted November 10, 2017 - 11:24 AM
I am surprised there is no zerk,but the axle doesnt have excessive slop so I guess its not needed. I can see where the bolt acts as a set screw and would keep the pin from turning ,letting the bushings do their job. Heck, its worked this long,I'm going to leave it as is.  Thanks for the responses!
David
