Ridemaster with wheel weights
4 replies to this topic
#1 Husky OFFLINE
Husky
  • 1,248 Thanks
  • 1,105 posts
Posted November 08, 2017 - 12:17 PM
This is an interesting picture from a Ridemaster catalog. It looks like they are using a standard wheel weight turned backwards and mounted to the ridemaster. Now, what color would the weight have been? Might be a neat thing to put onto the Ridemaster.
  • Bolens 1000, blackjackjakexxix, CRFarnsworth and 1 other said thanks
#2 wilberj ONLINE
wilberj
  • 4,974 Thanks
  • 5,586 posts
Posted November 08, 2017 - 05:27 PM
Those are the older 50s weights.  Newer Ridemasters had cut outs in the front rims so you could put the weights on.    You could also put the wheel weights on the back rims.  Bolens offers a wheel weight that could also go on the inside of the back rim so you could put two weights on each rear tire and one on each front tire.    So you could add 300 pounds to the tractor.
They also are yellow like the rims and seat.
  • Bolens 1000, Husky, Alc and 2 others have said thanks
#3 Husky OFFLINE
Husky
  • 1,248 Thanks
  • 1,105 posts
Posted November 08, 2017 - 07:50 PM
So they are different than the ones we put on the tube frame and large frame? I thought they might look good on a 1948 Ridemaster if they fit.
#4 wilberj ONLINE
wilberj
  • 4,974 Thanks
  • 5,586 posts
Posted November 08, 2017 - 08:35 PM
Yes they are.
  • Husky, Alc, drbish and 1 other said thanks
#5 Husky OFFLINE
Husky
  • 1,248 Thanks
  • 1,105 posts
Posted November 09, 2017 - 07:41 AM
Wow that's cool never seen anything like that before thank you for the picture.
  • wilberj said thank you
