Ultrasonic Parts Cleaner
26 replies to this topic
#1 HANKG OFFLINE
HANKG
  • 6,306 Thanks
  • 3,420 posts
Posted November 08, 2017 - 11:59 AM
IMG_1953.JPG IMG_1954.JPG Dropped a hunge on the cheap Harbor Freight ultrasonic parts cleaner today, but not before reading the reviews on Youtube. One guy pointed out something that made sense to me which was using silicon caulk on the seam just inside tank which separates the tank from the housing. He wrecked two of them, to see what the problem was he opened the unit and found a cheap flimsy silicon gasket in between the tank and the housing allowing the water in the tank to seep in to the electronic circuit board and frying the unit. That's what prompted the use of the silicon on the inside of the tank he says it has been operating fine since the upgrade we'll see.
  • olcowhand, daytime dave, Alc and 8 others have said thanks
#2 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted November 08, 2017 - 12:49 PM
This is the one I'm looking at buying and I hope to get one this spring.
https://www.amazon.c...c cleaner&psc=1
  • Alc and HANKG have said thanks
#3 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,341 Thanks
  • 1,324 posts
Posted November 08, 2017 - 12:52 PM
Should work great for carbs!
  • HANKG said thank you
#4 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 08, 2017 - 01:16 PM
attachicon.gifIMG_1953.JPGattachicon.gifIMG_1954.JPGDropped a hunge on the cheap Harbor Freight ultrasonic parts cleaner today, but not before reading the reviews on Youtube. One guy pointed out something that made sense to me which was using silicon caulk on the seam just inside tank which separates the tank from the housing. He wrecked two of them, to see what the problem was he opened the unit and found a cheap flimsy silicon gasket in between the tank and the housing allowing the water in the tank to seep in to the electronic circuit board and frying the unit. That's what prompted the use of the silicon on the inside of the tank he says it has been operating fine since the upgrade we'll see.
Thanks for the heads up on that! Might get one of those at some time!
#5 Bob White12 ONLINE
Bob White12
  • 132 Thanks
  • 132 posts
Posted November 08, 2017 - 01:17 PM
wow I know I could use one of those!! I wonder if I could make one. I once saw someone on YouTube just have a massive pot and a big fire beneath it isn't that the concept of it? what is the oil inside isn't just a heavy oil or kerosene of some sort? or do they have there own special oil that you can buy?
#6 jms180 OFFLINE
jms180
  • 1,511 Thanks
  • 1,564 posts
Posted November 08, 2017 - 01:59 PM
I have the smaller version of this one and it works great. Only disadvantage it is small only can do small carbs like single cylinder carbs. I use distilled water and about a table spoon of simple green or the purple cleaner. It has the adjustable heat and the vibration works great.
Edited by jms180, November 08, 2017 - 02:01 PM.
#7 Jazz OFFLINE
Jazz
  • 2,391 Thanks
  • 1,440 posts
Posted November 08, 2017 - 02:36 PM
I would not use silicone as it really lacks adhesive properties.  I suggest seam sealer from Napa or where ever. Its will bond to metals and plastics and seals as well.
  • Alc, KennyP and TomLGT195 have said thanks
#8 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,807 Thanks
  • 1,004 posts
Posted November 08, 2017 - 03:03 PM
Sounds like you are thinking of a hot tank, which uses heat and a strong lye solution to clean steel and iron. Or a heated parts washer, which uses a solvent for stuff that can't go in the lye.
This uses very high frequency sound waves, well above human hearing, to shake the grunge off parts. I use them at the university to clean everything from machine parts to microminiature lab-on-a-chip stuff.
  • Alc, KennyP, TomLGT195 and 2 others have said thanks
#9 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted November 08, 2017 - 03:14 PM
I figure I would save tons in cans of carb cleaner
  • HANKG and Jazz have said thanks
#10 olcowhand ONLINE
  • 41,092 Thanks
  • 31,402 posts
Posted November 08, 2017 - 04:35 PM
Hank, I have that same cleaner, and it works surprisingly well.  Thanks for the tip....mine will be getting silicone!
  • Alc, KennyP, HANKG and 1 other said thanks
#11 James Bosma OFFLINE
James Bosma
  • 1,317 Thanks
  • 652 posts
Posted November 08, 2017 - 05:08 PM
Why wait till spring
Buy it for the Mrs for Christmas and say its a ultrasonic jewelry cleaner and you will be happy to store it in the shop for her
  • Alc, KennyP, WNYTractorTinkerer and 3 others have said thanks
#12 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 08, 2017 - 05:56 PM
What about those of us with out a Mrs,?
#13 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted November 08, 2017 - 06:01 PM
I would have to get one first but then I would be broke all the time and couldn't afford one.
#14 olcowhand ONLINE
  • 41,092 Thanks
  • 31,402 posts
Posted November 08, 2017 - 06:05 PM
Just find your feminine side Kenny, then let "her" buy it for you!  :smilewink:
  • KennyP, CRFarnsworth, HANKG and 1 other said thanks
#15 CRFarnsworth ONLINE
CRFarnsworth
  • 4,665 Thanks
  • 2,140 posts
Posted November 08, 2017 - 06:07 PM
I have the 6L size of that model.  So far it has worked well.   Rick
