Shear bolts 1996 Troy-bilt/Bolens snow thrower
5 replies to this topic
#1 tlavergne OFFLINE
tlavergne
  • 23 Thanks
  • 11 posts
Posted November 06, 2017 - 06:19 PM
I have a Troy-bilt/Bolens snow thrower for my Troy-bilt GTX 16. I need shear bolts 1/4" x 1" grade 5 and 5/16" x 2 1/4". Can't locate any. Does anyone know of a source for these?
Thanks
#2 Kurtee OFFLINE
Kurtee
  • 585 Thanks
  • 467 posts
Posted November 06, 2017 - 06:56 PM
ebay, Fastenal, or any bolt house should be able to help you. Also JD or CaseIH dealers have bolts.
#3 boyscout862 ONLINE
  • 12,846 Thanks
  • 9,169 posts
Posted November 06, 2017 - 07:12 PM
Walmart, Home Depot, or Lowes should have them too. Make sure that the groves match the inner shaft. Using regular bolts can take out the gears in the auger gear box. Good Luck, Rick
#4 tractorskipper OFFLINE
tractorskipper
  • 474 Thanks
  • 304 posts
Posted November 06, 2017 - 08:38 PM
Would you really use a grade 5 for a shear bolt?
I didn't know there were shear bolts on my Bolens blower & I took out the input shaft, broke right off inside the housing!
Skip
#5 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted November 09, 2017 - 01:37 PM
The Bolens/ Troy bilt ones were not obtainable through local sources the OEM were special designed
Can you post the model or photo of the Blower I should have them instock but need to verify they are the ones I'm thinking of
  • Jazz said thank you
#6 tlavergne OFFLINE
tlavergne
  • 23 Thanks
  • 11 posts
Posted December 03, 2017 - 09:13 PM
Sorry...just got back to this and saw your post.
Snowblower Model #14063.
1/4" x 1" Grade 5 (so says parts manual)  Part # 1825092
5/16" x 2 1/4"  Part # 1825235
