Flat wheel weight washers
31 replies to this topic
#1 Husky OFFLINE
Husky
  • 1,341 Thanks
  • 1,151 posts
Posted November 06, 2017 - 04:30 PM
Would anyone know where I could get the flat wheel weight mounting washers? I've got three sets to put on my 1250. One set is on now I may add one or two more for when I go to a show. Thank you for any info.
  • Bolens 1000 and blackjackjakexxix have said thanks
#2 kjmweld ONLINE
kjmweld
  • 646 Thanks
  • 400 posts
Posted November 06, 2017 - 05:19 PM
I need a whole bunch of them myself... been asking around for months now & still nothing. Best of luck to you tho.
#3 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted November 06, 2017 - 05:48 PM
you might have to make them.
hope somebody and tell you the thickness, the hole spacing and hole size.
good luck
#4 olcowhand ONLINE
  • 43,176 Thanks
  • 32,012 posts
Posted November 06, 2017 - 05:54 PM
Member hammerdown has been thinking of doing some custom plasma cutting jobs.  Maybe you guys can get with him to make you some.
  • Bolens 1000, blackjackjakexxix and KennyP have said thanks
#5 classic ONLINE
classic
  • 5,695 Thanks
  • 2,386 posts
Posted November 06, 2017 - 06:05 PM
We use grade 8 washers at work that have a smaller outer diameter than a common flat washer, and they may fit in the wheel weight pocket. You can probably get a bag of 100 for 8 to 10 bucks for 1/2" grade 8 washers. They are thicker than standard flat washers, too.
#6 wilberj OFFLINE
wilberj
  • 5,136 Thanks
  • 5,636 posts
Posted November 06, 2017 - 06:09 PM
Its more then a simple washer lol.   I'll take one to the shop and look into making them....
#7 classic ONLINE
classic
  • 5,695 Thanks
  • 2,386 posts
Posted November 06, 2017 - 06:15 PM
A pic of one would help.
#8 chieffan OFFLINE
  • 11,781 Thanks
  • 7,284 posts
Posted November 06, 2017 - 06:54 PM
​Never been that route so wonder what is special about those washers?  Have a pair of Bolens weights mounted using standard washers.  Must be in the stacking process?
#9 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,771 Thanks
  • 1,916 posts
Posted November 06, 2017 - 06:56 PM
I've always used standard washers too haha. Never heard of them till now
#10 wilberj OFFLINE
wilberj
  • 5,136 Thanks
  • 5,636 posts
Posted November 06, 2017 - 07:18 PM
Yep its for stacking them.
Edited by wilberj, November 06, 2017 - 07:20 PM.
  • Alc, Cat385B and kjmweld have said thanks
#11 Husky OFFLINE
Husky
  • 1,341 Thanks
  • 1,151 posts
Posted November 06, 2017 - 07:26 PM
Sorry , I should have been more specific on the washers. They are indeed unique as wilburj has shown in his photo.
  • wilberj said thank you
#12 JBRamsey OFFLINE
JBRamsey
  • 1,594 Thanks
  • 886 posts
Posted November 06, 2017 - 07:46 PM
Find you a shop with a laser cutter. They can knock a bunch out for you in a few minutes.
  • Husky said thank you
#13 EricFromPa ONLINE
EricFromPa
  • 4,309 Thanks
  • 3,416 posts
Posted November 06, 2017 - 08:53 PM
Looks like they would be simple enough to make out of Bar stock. Measure and cut a little long with a Chop saw. Center punch and with a drill press, Drill and tap 1 hole and drill the other hole and round off the corners with a bench grinder.
If I had dimensions and some heavy 1" wide bar stock I could make them.
Wonder if they are heat treated?  Only way to tell is with a File test. Soft mild steel a file will want to grab into. Hardened steel will make a file skate off.
  • Husky and lyall have said thanks
#14 wilberj OFFLINE
wilberj
  • 5,136 Thanks
  • 5,636 posts
Posted November 06, 2017 - 10:10 PM
I work at a shop that does this work every day I'll see how many I can knock off on the Haas this week if I get time.   Hopefully some will still need them by then. lol
  • Husky and EricFromPa have said thanks
#15 mjes92 OFFLINE
mjes92
  • 39 Thanks
  • 32 posts
Posted November 06, 2017 - 10:20 PM
I have a detailed drawing I can try to post tomorrow.  One hole is a through hole for a 1/2 bolt.  The other is a tapped 1/2-18 NF (fine thread) I believe.  The FMC version of your pictured Bolens weight states max stack of three weights. Casted right into the weight.  The Bolens weight does not state a max but I wouldn't push it past three.
  • Husky, Alc and blackjackjakexxix have said thanks
