Sears Transaxle Flush
7 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,476 Thanks
  • 3,069 posts
Posted November 06, 2017 - 04:14 PM
What does everyone use to flush the transaxles out ? I'm about to flush out the SS15.
#2 tater195 ONLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted November 06, 2017 - 04:34 PM
Gear or hydro? I have a 633 I need to clean up, but not sure I have time to split the case and inspect everything. It will be out of the unit and I plan to drain oil, pour in a few qts of diesel and slosh it around, give it time to soak good and drain.
#3 bbuckler OFFLINE
bbuckler
  • 3,476 Thanks
  • 3,069 posts
Posted November 06, 2017 - 04:35 PM
Gear. Also need to find axle seals. Sears has them but $22 a piece
#4 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted November 07, 2017 - 03:22 AM
intech bearing
listed by size
I got my $25 list price bolens seals
for $3.25 each
or
usa belts and bearings
  • bbuckler and 6mikey7 have said thanks
#5 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted November 07, 2017 - 04:20 AM
Diesel fuel or Kerosene works decent for flushing.   Gasoline works better for breaking up the sludge but you'll have to flush with Kero or Diesel afterwards to remove the gas.
I had the shifter out to replace the seal on the shifter so I drained the water and disgusting brown muck out of the tranny and dumped almost a gallon of K1 Kerosene in the shifter hole and jacked up the rear of the tractor,  Started it and put it in 1st gear and let it run for 10-15 minutes.  Just 1st gear and don't run it any faster than a idle.
Don't forget to replace the Shifter seal. That's the one that is letting all of the water into the tranny. I bet yours is either ripped or completely blown out. They all are.
The shifter seal is only $4 + shipping.  All of the sears tractors with the Peerless 3 speed and Peerless 3 speed with Hi/Lo use the same seal.
Part Number: 532110542
https://www.searspar...dName=CRAFTSMAN
Edited by EricFromPa, November 07, 2017 - 04:28 AM.
  • KennyP and 6mikey7 have said thanks
#6 John Arsenault OFFLINE
John Arsenault
  • 2,601 Thanks
  • 1,219 posts
Posted November 07, 2017 - 07:29 AM
When I bought my Sears and pulled the drain plug I thought , ut oh something is wrong. Come to find out the common milky sludge is from keeping the tractor outside in the rain. I found the seal on top and changed that right away. I used kerosene to flush my transmission with but when it came time for re-filling I decided to go with an outboard gear lube, it has additives in there that help the oil not to break down into milky sludge so easy when water is introduced . At least now I know if I get a little water in there between changes I got oil in it that was designed to get a little water in it.
  • bbuckler said thank you
#7 bbuckler OFFLINE
bbuckler
  • 3,476 Thanks
  • 3,069 posts
Posted November 07, 2017 - 08:39 AM
Thanks Guys, I guess while I'm at it I need to buy the liner and fix the brake too.
#8 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted November 12, 2017 - 07:03 PM
GASP!!!! OMG you guys leave your tractors outside????? LOL I have a pole barn I built for mine and they don't see water unless it's bath day, which is few and far between unfortunately. When I had the trans stuck on my suburban I followed directions and used the gas method, then some diesel, and back to gear oil. Works great now without issues. A big thanks to the guys on this site for directing me to try it before ripping down. :thumbs:
