Massey Ferguson 1655 Rear Hub Removal
axle hub puller wheel
3 replies to this topic
#1 Rich Ford OFFLINE
Rich Ford
  • 3 posts
Posted November 06, 2017 - 02:43 PM
I need to get one of the rear hubs off so I can have some work done on the axle housing. The hub pullers I have, one is a 5 ton, just isn't getting it done. The nut and washer are off. I don't see anything other than the key way for the hub. There is no set screw so I'm not sure why this thing won't come off. Any ideas?
#2 KennyP ONLINE
  • 37,450 Thanks
  • 45,472 posts
Posted November 06, 2017 - 03:18 PM
I think that is a beveled axle, so they would be similar to a flywheel coming off. Try some nice love taps on the end of the puller!
#3 Bob White12 OFFLINE
Bob White12
  • 118 Thanks
  • 114 posts
Posted November 06, 2017 - 03:42 PM
 I've seen some people tighten it up all the way then leave it there for an hour or even a day then come back every now and then and tap and tighten a little more.
#4 dropped82 ONLINE
dropped82
    Nut Case
  • 2,448 Thanks
  • 1,795 posts
Posted November 06, 2017 - 04:27 PM
Here was my successful method on my 1655. Popped right off.1479094880431.jpg
  • CRFarnsworth said thank you
Also tagged with one or more of these keywords: axle, hub, puller, wheel
