Really Rusted Together
18 replies to this topic
#1 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,979 Thanks
  • 9,624 posts
Posted November 06, 2017 - 02:18 PM
I have an equalizer hitch to pull my camper. Because my new pick up is taller than the old one by several inches; I wanted to take the ball mount apart and readjust the heighth. I couldn't undo the bolts with a 1/2" breaker and a long pipe at all!​ So, over to a local equipment rental shop where I know the owner and his mechanic. Well, his air powered impact wrench wouldn't take the 1 1/16th aircraft nuts off, even after persuading with an air hammer. Break out the torch and heat them up - off they came. Now for the bolts which for some reason have an 1 1/8th head. The first one which goes through a slotted hole was removed with a lot of impact wrench. Remember all that's holding these two bolts in is rust. Now for the last hole, nothing would remove it.    Not heat, not cussing. The last chance was a large press in the back room. He rigged it up on there and started. The bolted moved and as each thread entered the hole, the press made a loud bang, over and over. I thought for sure it was stripping threads.  Nope, just rust.
I'm for sure going to do a thorough cleaning and install new bolts.
  • Gtractor, hamman, KennyP and 3 others have said thanks
#2 KennyP ONLINE
  • 37,478 Thanks
  • 45,497 posts
Posted November 06, 2017 - 03:20 PM
Some anti-seize might help!
  • Alc, hamman, MFDAC and 4 others have said thanks
#3 poncho62 OFFLINE
poncho62
  • 1,603 Thanks
  • 1,612 posts
Posted November 06, 2017 - 06:22 PM
One reason that I always take my hitch ball out of the receiver, don't want it to rust in there......That and it's murder on the shins.
I would suggest taking your ball mount apart at least once a year.
  • hamman, MFDAC, boyscout862 and 2 others have said thanks
#4 tractorskipper OFFLINE
tractorskipper
  • 397 Thanks
  • 274 posts
Posted November 06, 2017 - 08:43 PM
I've heard that in PA it is illegal to leave your "unused" hitch in place.
  • LilysDad and Jazz have said thanks
#5 shorty ONLINE
shorty
  • 5,279 Thanks
  • 5,168 posts
Posted November 06, 2017 - 08:52 PM
Yup. We have a law for anything and every thing.
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted November 06, 2017 - 09:15 PM
Wait until you need the spare tire from under the bed and turning the crank does nothing.
You're going to need to up your cussing quality.
  • Cvans and LilysDad have said thanks
#7 916hydro OFFLINE
916hydro
  • 72 Thanks
  • 71 posts
Posted November 06, 2017 - 09:51 PM
Can you get stainless bolts that big? Might be worth the extra$$
#8 Greasy6020 ONLINE
Greasy6020
  • 1,383 Thanks
  • 1,341 posts
Posted November 07, 2017 - 01:47 AM
I'm offering lessons in that department. I make old truckers cover their ears when I'm in a foul mood.
#9 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,979 Thanks
  • 9,624 posts
Posted November 07, 2017 - 07:39 AM
Where would you put your 'Bull Nuts'?
Would they equal the strength of the #5 bolts that are in there now?
#10 SimplyRad OFFLINE
SimplyRad
  • 1,019 Thanks
  • 785 posts
Posted November 08, 2017 - 12:30 PM
When you step up to a sailor's cussing then you are in the BIG league.
When I made my hitch I turned down 3/4" grade 8 bolts to 5/8" with fine thread grade 8 nuts. I try not to leave it in the bad weather any more than I have to. Had to adjust it this summer for a lower hitch point.
#11 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted November 08, 2017 - 02:16 PM
Ditto, I take mine out and lock it up in the cab, mine was expensive and I don't want it stolen, here is a pic of one like mine.
#12 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,979 Thanks
  • 9,624 posts
Posted November 08, 2017 - 03:13 PM
Aren't grade 8 bolts available in 5/8?
#13 KennyP ONLINE
  • 37,478 Thanks
  • 45,497 posts
Posted November 08, 2017 - 03:36 PM
Yes!
#14 SimplyRad OFFLINE
SimplyRad
  • 1,019 Thanks
  • 785 posts
Posted November 10, 2017 - 09:34 AM
They didn't have them where I worked  and the 3/4 was free. Free and a lathe is good. This is a Bock equalizing hitch and just copied a buddies and made each part and had our blacksmith weld it together. I would have made a 2 5/16 stainless ball but didn't have a radius gauge.
  • Alc and LilysDad have said thanks
#15 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,979 Thanks
  • 9,624 posts
Posted November 10, 2017 - 12:38 PM
Very impressive!!!
