JD 300 HYD/PLOW ?
7 replies to this topic
#1 CATWRENCH855 OFFLINE
CATWRENCH855
  • 1 posts
Posted November 05, 2017 - 08:41 PM
Hey guys first post on here and needing some help. I just bought a real nice JD 300. It only has one set of hyd couplers on the front and I am wanting to add the second set so I can run a blade that has tilt and lift. I know u can run the rock shaft lift for the tilt. But my question is is there a company out there where u can get a kit to plumb all this up with the hoses, fittings, quick connects for the front and the valve that will shut off the rock shaft cylinder so you don't have to wait for it to cycle? I know I could piece it together but a kit would be handy. Also I am located in central IL if anybody is halfway close that has a 54" blade with tilt/lift I am in the market. Any advice helps thanks in advance.
#2 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 510 Thanks
  • 389 posts
Posted November 05, 2017 - 11:08 PM
You can try Auxillary Hydraulics, they make rear kits for the 120,140 and closed framed 300 series, also early 400 series. Surprised it only has one set of couplers, most 300's came with two.
#3 dodge trucker ONLINE
dodge trucker
  • 2,429 Thanks
  • 3,120 posts
Posted November 06, 2017 - 07:15 AM
someone else from Illinois , I see....
#4 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted November 06, 2017 - 08:42 AM
Hello and welcome! :welcome: Glad u found this site.
 A John Deere 300 is a great tractor.  Best thing is its green!   :D
Do you have 1 or 2 hyd. levers on the left side?   Strange that is only has the one set of couplers.  p.s.  got any pictures?
#5 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted November 06, 2017 - 09:32 AM
As I read this the first thing that came to my mind is, "This guy has a 314 (or possibly a 312) with a 300 hood on it."
ALL 300/316K got the dual front remotes from the factory.  Some 312s got one set and all 314s have single front remotes.  Got any pics of the serial tag?
Edited by Trav1s, November 06, 2017 - 09:32 AM.
  • KennyP and Leonard VanCamp have said thanks
#6 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 06, 2017 - 12:49 PM
Good info to know!
#7 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted November 07, 2017 - 05:55 PM
Any more info on this mystery machine?
#8 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted November 08, 2017 - 10:00 AM
If it is a 314 then parts from a 317 would be an easy swap and pretty easy to find.  A quick google search will show numerous conversions.  I am using 300/316 parts for my 312 but the 312 is tricky because there were some changes in the production run of the 300/316 and 312 that can create confusion.
