Garden is done
5 replies to this topic
#1 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted November 05, 2017 - 01:50 PM
Took some time today in the chilly morning to wheel harrow my garden. This harrow is a beast. It probably weighs 250-300 lbs by itself. I tried using my Wheel horse at first, but the front end is way too light so I couldn’t steer . I hooked up my Belen’s, locked the rear hub up, 3rd gear low range and off I go.
  • Alc, KennyP, CRFarnsworth and 6 others have said thanks
#2 KennyP ONLINE
  • 38,304 Thanks
  • 45,899 posts
Posted November 05, 2017 - 02:53 PM
Looks like quality seat time! Nice disc!
  • pharmer said thank you
#3 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted November 05, 2017 - 04:20 PM
Your garden soil looks great after disking it  :thumbs:   I don't think I have enough weight on mine to do it that well
#4 ShotgunWedding OFFLINE
ShotgunWedding
    Garlic Jedi
  • 629 Thanks
  • 284 posts
Posted November 06, 2017 - 11:02 AM
That turned out really nice!!!
#5 Greasy6020 OFFLINE
Greasy6020
  • 1,476 Thanks
  • 1,399 posts
Posted November 06, 2017 - 11:20 AM
Do you plow before you disk, or just make multiple passes?
I'd have to plow before I touch it with the disk otherwise I'm just knocking down the weeds and not much else. If I put enough weight on to do anything I bend the snot out of either the drawbar or hitch of the disk. Or sit and spin.
  • KennyP and pharmer have said thanks
#6 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted November 06, 2017 - 12:24 PM
I pull all the plants out first and then just run the disc up and down the length several times. It’s a heavy disc so it has no problem slicing up the weeds and leaves. I even cut through any pumpkins left out . In the spring Usually run my plow first because the ground is much harder.
  • KennyP, oldedeeres and Greasy6020 have said thanks
