1655 rear lift
24 replies to this topic
#1 bolen1 OFFLINE
bolen1
  • 21 Thanks
  • 27 posts
Posted November 03, 2017 - 03:54 PM
Does anyone know if Massey 1655 is supposed to have down pressure or is it float only on 3 pt.
Looks like needs stop welded to linkage to get down pressure.
#2 dropped82 ONLINE
dropped82
    Nut Case
  • 2,675 Thanks
  • 1,880 posts
Posted November 03, 2017 - 04:00 PM
Mine doesn't have down pressure. The rockshaft kinda "sits" on the cylinder. There's no float on the valve side of it. Now if you did weld it solid, I'd switch lines with the belly lift. That way you'll have float in the valve instead.
  • bolen1 said thank you
#3 bolen1 OFFLINE
bolen1
  • 21 Thanks
  • 27 posts
Posted November 03, 2017 - 04:12 PM
So the spool valve for belly lift has float and pressure?
#4 dropped82 ONLINE
dropped82
    Nut Case
  • 2,675 Thanks
  • 1,880 posts
Posted November 03, 2017 - 04:14 PM
Or better yet, get another valve with float and stack it onto the existing set. Adding a 3rd spool with float. I believe all the 50 and 55 series Masseys had float on the belly lift. So it'll be the most common valve to find.
#5 bolen1 OFFLINE
bolen1
  • 21 Thanks
  • 27 posts
Posted November 03, 2017 - 04:15 PM
I need a spool valve the belly valve end broke off and is stuck also.Any ideas where to find one .
#6 dropped82 ONLINE
dropped82
    Nut Case
  • 2,675 Thanks
  • 1,880 posts
I'm actually out working on mine now and yes. Look at yours, it should be the same.20171103_171501.jpg
#7 dropped82 ONLINE
dropped82
    Nut Case
  • 2,675 Thanks
  • 1,880 posts
Posted November 03, 2017 - 04:16 PM
Check eBay. Although not the cheapest, Joes outdoor is parting 2 55 series.
He's not the cheapest but I've never gotten a bad part from him. Plus he usually has what I'm looking for.
Edited by dropped82, November 03, 2017 - 04:17 PM.
#8 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted November 03, 2017 - 04:18 PM
I believe mine has down pressure.
#9 dropped82 ONLINE
dropped82
    Nut Case
  • 2,675 Thanks
  • 1,880 posts
Posted November 03, 2017 - 04:50 PM
Your 3 point?
Mechanically it shouldn't. You can grab the lift arms and pick them up. If not then someone has already modified it. As for the valve, the 3 point is normally hooked to the middle valve. That valve does not have a float built into it.
Edited by dropped82, November 03, 2017 - 04:51 PM.
#10 dropped82 ONLINE
dropped82
    Nut Case
  • 2,675 Thanks
  • 1,880 posts
Posted November 03, 2017 - 04:53 PM
I've considered welding mine solid out back. I have a loader on my 1655 so the belly cylinder is not and will never be usable. I'm going to switch my 3 point to the first valve once I find time somewhere!! Still trying to finish installing this 24hp Onan right now.
#11 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted November 03, 2017 - 08:39 PM
I believe hydraulically it has down pressure, havent had it running in a while though.
#12 mac102004 ONLINE
mac102004
  • 395 Thanks
  • 438 posts
Posted November 05, 2017 - 06:51 AM
The 3pt is designed not to have down pressure, the hydraulic cylinder is double acting and the valve has no float position for it, but it's in the design of the 3pt itself.
  • DMAX, ducky, dropped82 and 2 others have said thanks
#13 bolen1 OFFLINE
bolen1
  • 21 Thanks
  • 27 posts
Posted November 05, 2017 - 07:49 PM
I'm actually out working on mine now and yes. Look at yours, it should be the same.attachicon.gif20171103_171501.jpg
mine is missing the plastic cover,but can see one for deck has longer spool. Guess I'll call joes outdoor parts on 2spool valve.
#14 dropped82 ONLINE
dropped82
    Nut Case
  • 2,675 Thanks
  • 1,880 posts
Posted November 05, 2017 - 07:50 PM
There is a member here sell parts off one. Jpswft I believe. He has posts in this forum about his 1855. You might check with him first.
  • DMAX, limebuzz, bolen1 and 1 other said thanks
#15 limebuzz OFFLINE
limebuzz
  • 1,055 Thanks
  • 1,005 posts
Posted November 05, 2017 - 09:33 PM
Jeff's a decent guy to deal with. I think he is in MY.????
  • DMAX and jpswift1 have said thanks
