Tire/Wheel Dilema
7 replies to this topic
#1 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted November 01, 2017 - 12:06 PM
I was given this pair of Carlisle Reliant semi-pneumatic tires/wheels some time back. They had bearing races in them, but no bearings. Found a set of 3/4" trailer bearings fit perfectly. So now I have to decide where to use them. Option #1 is trailing wheels for a pull-behind mower. Option #2 is trailing wheels on a pull behind grader. There may be an option #3 before I put them to use.
They are 13X5.00-6/3.25 in size.
  • olcowhand, Jazz and CanadianHobbyFarmer have said thanks
#2 James Bosma OFFLINE
James Bosma
  • 1,145 Thanks
  • 580 posts
Posted November 01, 2017 - 03:52 PM
Yes that is a very tough decesion for those nice wheels,  Can save you the pain of deciding and just ship them to me. Just let me know what shipping will be.  Oh and thanks for finding out what bearings work.
The grader blade sounds handy and good use of the wheels, hope the seals are good to keep all the dust out
Do any heavy moving, see they take 440 lbs., good for water wagon too
  • KennyP, Trav1s and WNYTractorTinkerer have said thanks
#3 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted November 01, 2017 - 04:00 PM
Thanks for adding more options! :smilewink:
  • James Bosma said thank you
#4 James Bosma OFFLINE
James Bosma
  • 1,145 Thanks
  • 580 posts
Posted November 01, 2017 - 04:05 PM
Ummm  do you do fire wood   nice wood spliter wheels too   need more   :rolling:
Need to get you 20 options
Then pin to dart board
Throw dart and that's your project
Edited by James Bosma, November 01, 2017 - 04:08 PM.
  • Jazz said thank you
#5 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted November 01, 2017 - 04:09 PM
I can borrow a spliter anytime I want as long as it's not in use. I may have a set of air tires I can use for one of these projects! Probably best to use these behind the mower so they don't go flat! I have some smaller semi-pneumatic ones I can use for the front swivels on the mower. Now to come up with a set of fronts for the grader blade.
  • olcowhand and James Bosma have said thanks
#6 olcowhand ONLINE
  • 40,313 Thanks
  • 31,161 posts
Posted November 01, 2017 - 08:07 PM
Anytime you can use airless tires it's good.  I put one foam filled tire on the front of my John Deere F935's deck, and when the other air tire goes, I'll try and find another foam filled one.  Sure is nice not worrying about flats, and on decks they seem to have flats way more often.
  • KennyP and Jazz have said thanks
#7 Jazz OFFLINE
Jazz
  • 2,291 Thanks
  • 1,399 posts
Posted December 01, 2017 - 08:23 AM
Never seen semi pneumatics that large. I would put them on all 4 corners.
Got them in a 22.5?:)
Had a typical Monday last week with 60k of fish on board
#8 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted December 01, 2017 - 08:57 AM
That wasn't fun!
