HH120 Carb
4 replies to this topic
#1 JJORAY OFFLINE
JJORAY
  • 2 posts
Posted November 01, 2017 - 10:14 AM
My grandfather is in the final stages of restoring a 1970 SS12. He had it running like a top when he started doing the restoration about 8 months ago. The engine was rebuilt last winter, and maybe had 4 or 5 hours on it since then. The tractor for the most part has had an easy life. But when he got it together last weekend we couldn't get it to run. No matter what we do. Now ive search and have found the carbs for like 150-200 bucks because we want to kick the problem in the butt, but he doesnt want to spend that amount of money after already putting enough money into it. Would we be better off spending the 30 for the carb rebuild or just a whole new carb? I perosnally own IH Cubs so have no idea about these sears machines. Any info would be greatly appreciated!
#2 Bolens 1000 ONLINE
  • 14,926 Thanks
  • 18,112 posts
Posted November 01, 2017 - 10:19 AM
Welcome to GTT :wave:
If there is nothign seriously wrong with the old carburetor I'd rebuilt it , I would need to know the carb numbers off the body but I do stock the kits for them.
Other option is converting them to a new Tecumseh made carb which is $100
If your air cleaner mounts like this picture it will be a bolt on replacement
  • Gtractor said thank you
#3 James Bosma ONLINE
James Bosma
  • 1,179 Thanks
  • 596 posts
Posted November 01, 2017 - 04:04 PM
Welcome
Can the original carb be rebuilt as mentioned
Rumor has it that the carb for a Kohler K321 (14 hp.) or K341 (16 hp.) will bolt right on
Around 20 to 30 dollars off Ebay shipped to your door
According to this thread
http://gardentractor...oh140-tecumseh/
I believe you will need a Kohler air cleaner for proper choke operation
  • 6mikey7 said thank you
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,245 Thanks
  • 5,556 posts
Posted November 02, 2017 - 05:38 PM
When you say it won't run does if fire at all? Is there good spark?
#5 JJORAY OFFLINE
JJORAY
  • 2 posts
Posted November 03, 2017 - 09:53 AM
Gets fire just wont run...
