Nominations For Tractor of the Month December 2017
  • This topic is locked This topic is locked
16 replies to this topic
#16 James Bosma OFFLINE
James Bosma
  • 1,384 Thanks
  • 685 posts
Posted November 19, 2017 - 09:59 PM
Love playing in the snow
Its the reason I got a GT is for snowblower for winter
  • propane1 and John Arsenault have said thanks
#17 TomLGT195 ONLINE
  • 3,928 Thanks
  • 2,849 posts
Posted November 21, 2017 - 04:28 AM
    General Electric E15 battery powered snow plow. I got this a few yrs ago took it all apart repaired, repainted and replaced the original control circuits with a modern electronic controller. Tractor is used for as many different jobs as I can, grass cutting, garden plowing, cultivating, leveling out the driveway, it has gone to plowdays and tractor pulls.
    In the winter I plan to use it for plowing the snow off the driveway. Tractor has Loaded AG tires, 250lbs of suitcase weights, 30lbs front wheel weights and 50lbs rear wheel weights.  Factory 48" blade that has electric lift and hand control angle. I also have a factory snow thrower and back blade for it. Takes 15 minutes to switch the snow plow to a snow thrower. Hopefully we get enough snow that I can give it a real test to see how it does.
Doug, I like the back blade setup with the snow blower, get you right up to the buildings or vehicles without turning around. Hope you get enough snow to try it out. Maybe even a video??
  • DH1 said thank you
