Would you replace all the injectors on a pick up truck when one fails?
32 replies to this topic
#1 MiCarl ONLINE
MiCarl
  • 1,911 Thanks
  • 1,019 posts
Posted October 31, 2017 - 06:10 AM
My 2007 Chevrolet Colorado with the 5 cylinder engine seems to need a new fuel injector on cylinder 5.  The truck has 175,000 miles on it.
There is a lot to disassemble to get to the fuel rail and all 5 injectors will come out with it.  I hate to do all that work again if another injector acts up in the near future.  Injectors run about $50 apiece from rock auto so it would add $200 to the tab if I just do all 5.
What would you do?
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,849 Thanks
  • 4,952 posts
Posted October 31, 2017 - 06:19 AM
Are you buying Delco injectors from Rock Auto? I'm not a big fan of aftermarket parts in some applications and this would be one of them. Don't think I've ever had a bad injector in one of those engines but anything is possible. What is it doing? I see more coil problems on them than anything.
  • Gtractor and Jazz have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,107 Thanks
  • 4,882 posts
Posted October 31, 2017 - 06:29 AM
My opinion is 175000 is pretty good service on a wear item like that and at only $50 each...  yes,  I'd replace all.
Last place I worked ran diesel pickups and the dealer got over $1000 each to change out an injector, so they were one at a time.
  • Cvans and Mark 149 J. have said thanks
#4 MiCarl ONLINE
MiCarl
  • 1,911 Thanks
  • 1,019 posts
Posted October 31, 2017 - 06:34 AM
AC Delco injectors.  I was mistaken, they're $40 apiece.
The truck was periodically throwing a check engine light - miss fire cylinder 5.  Seemed to only happen when idling for long periods with the AC on.  I couldn't get it to reliably throw a code though.  I swapped coils and plugs around but the problem continued to occur on cylinder 5.  I checked with my local shop to see if I should bring it in or wait for it to get worse.  They recommended waiting but suggested in the meantime to run injector cleaner as it's likely an injector.
Now it's happening pretty regularly, even without the AC compressor running.  Yesterday as I pulled from a stop it ran noticeably rough, then smoothed out.  The MIL came on, miss fire cylinder 5.  It's time to do something about it.
I've decided to replace the #5 injector and am inclined to do all 5 while I'm in there.  Don't want to just throw away money though......
Edited by MiCarl, October 31, 2017 - 06:35 AM.
#5 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted October 31, 2017 - 07:09 AM
Time for a new truck, best idea!  :smilewink:  I'ld say 175K is plenty of miles for any vehicle I would own.
  • Reed Breneman said thank you
#6 jhn9840 ONLINE
jhn9840
  • 339 Thanks
  • 337 posts
Posted October 31, 2017 - 07:14 AM
If I had the cash to buy the extra 4 I would do them all. My. Luck, as soon as I got one done, one of the others would go.
jhn9840
John
  • Cvans said thank you
#7 MiCarl ONLINE
MiCarl
  • 1,911 Thanks
  • 1,019 posts
Posted October 31, 2017 - 07:38 AM
I drive them until they rust away.  This was a California truck until 3 years ago, it was cleaner underneath than on top.  I expect to put 250-300K miles on it.
#8 chieffan OFFLINE
  • 9,559 Thanks
  • 6,404 posts
Posted October 31, 2017 - 07:39 AM
​Definitely do all 5.  You don't want to have to go through all the disassemble each time one goes bad. If you changed the plugs around it is not a plug, but still get misfire on cylinder -5 ? ?  Sounds electrical problem to me, but could still be an injector.
#9 JBRamsey OFFLINE
JBRamsey
  • 1,412 Thanks
  • 813 posts
Posted October 31, 2017 - 07:43 AM
Our rule of thumb is if it's one or two injectors, just do the two. If it is more than two, then replace them all.
Are you doing the work or paying a shop? If I am doing the work, I would just replace the one and keep going. If you are paying a technician, then I would do all five.
175,000 is a lot of miles, but things have changed in the last 50 years. My last couple of trucks went over 350k and 300k each. My current truck is at 192k and runs like a top.
#10 MiCarl ONLINE
MiCarl
  • 1,911 Thanks
  • 1,019 posts
Posted October 31, 2017 - 08:50 AM
Ordered a full set and the manifold gaskets from Rock Auto.  Hopefully I can forget about them for another 175,000 miles.
Edited by MiCarl, October 31, 2017 - 08:50 AM.
  • Austen said thank you
#11 jms180 ONLINE
jms180
  • 1,473 Thanks
  • 1,542 posts
Posted October 31, 2017 - 09:02 AM
I had one to go bad on my truck it was much to remove to get to the injectors i just replaced them all. I had one that would not close completely and leaking fuel into the cylinder making for hard starting. After replacing all is good.
#12 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,125 Thanks
  • 1,210 posts
Posted October 31, 2017 - 09:34 AM
Ditto!
  • Gtractor said thank you
#13 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,190 Thanks
  • 5,666 posts
Posted October 31, 2017 - 09:35 AM
Ditto on the coil..  You're getting a misfire on #5 from the code reader, right?  I went through this on my '05 sierra and replaced the coil then when it came in again I contemplated replacing the injector as you are..  As it would turn out by searching the web I found that my whole problem was that my batteries went dead and as a result my crankshaft balance setting was lost in the computer.  I performed a a 'relearn' procedure with a scanner and the engine has run like a champ ever since sans the misfire crap..
Hope this is your problem too..
Edited by WNYTractorTinkerer, October 31, 2017 - 09:37 AM.
  • Gtractor and Mark 149 J. have said thanks
#14 DougT ONLINE
DougT
    Dog Approved
  • 6,849 Thanks
  • 4,952 posts
Posted October 31, 2017 - 09:50 AM
I checked the price on the Rock Auto injectors and they are cheaper than I can buy them through my Delco supplier and I'm an AC Delco shop. I'd do all of them if I was doing it on my own vehicle. Sometimes it's hard to convince a customer to do the extra but you can believe it would be my fault when the second one failed.
  • Gtractor and MiCarl have said thanks
#15 MiCarl ONLINE
MiCarl
  • 1,911 Thanks
  • 1,019 posts
Posted October 31, 2017 - 10:25 AM
I had swapped the spark plugs from #5 and #1 and the coils between #5 and #2.  The problem didn't move so it shouldn't be coil (coil over plug) or plug.  If it's electrical it'll be in the vehicle wiring or the module.  My experience is flaky electrical gets worse at higher RPM which is the opposite here.
If I clear the code it'll run down the freeway all day without throwing another.  Fuel mileage doesn't seem to be off so I think it's only a problem at idle.  Hopefully that injector is just not quite right.
I'll know after the new set is in.
  • Mark 149 J. said thank you
