Arien's EZR 2048 runs, but stops when control arms are moved
3 replies to this topic
#1 roc OFFLINE
roc
  • 1 posts
Posted October 30, 2017 - 04:48 PM
My Arien's runs well, but the moment I pull the control arms into center to drive the engine shuts off.  It does not matter if it is right or left control arm.  I checked safety interlock switches with digital MM and they seem fine.  I pulled the two relays up line and they also check out well.  I am not sure where to look next.
#2 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted October 30, 2017 - 05:48 PM
Don't know the unit but sounds like seat switch problem. Many use the seat switch to control the ignition. Operator falls out of seat so engine stops.
Garry
#3 jms180 OFFLINE
jms180
  • 1,477 Thanks
  • 1,544 posts
Posted October 30, 2017 - 05:56 PM
Garry
as Garry said check the seat switch and also the brake switch
#4 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted October 30, 2017 - 06:09 PM
Garry
Should have worded this different.
On many the pto switch controls the ignition when the pto is OFF.
When the pto is ON the seat switch controls the ignition.
They may also have switches on the control arms that give the seat switch ignition control.
Garry
