* * * * - 1 votes
Massey 1450 Rear Axle Seal Help
massey rear seals
10 replies to this topic
#1 Cribs1450 OFFLINE
Cribs1450
  • 46 Thanks
  • 22 posts
Posted October 30, 2017 - 01:12 PM
Hey GT,
This is my first post, I've been a long time lurker,  I am sure there are other forums to this topic but figured this is the quickest way to get results.  I am at my wits end with replacing the rear axle seals for my 1450.  I will be ordering 2 new ones today from AGCO parts. which runs me about 65 CAD.  I am assuming the issue is when I install them they are getting ruined by the thread in which the wheel hub goes over on the axle.  IF there is any tips of the trade to help me stop this madness it would be greatly appreciated.
  • dropped82 and pryan05 have said thanks
#2 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted October 30, 2017 - 02:35 PM
Grease the axle and threads before sliding the tube back on. That’ll help save the seal during installation.
Sent from my iPad using Tapatalk
  • Cribs1450 said thank you
#3 sharkman OFFLINE
sharkman
  • 358 Thanks
  • 283 posts
Posted October 30, 2017 - 03:20 PM
$65 seem kind of high for 2 seals. BTW nice rear blade, they must be kind of rare!
  • dropped82 and Cribs1450 have said thanks
#4 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted October 30, 2017 - 04:05 PM
The Massey 1450 has a Peerless rear axle correct? I got the seals for my 1655 at Napa.
National seal 481792 [ 1.125 x 2.125 x 0.250 ]
This is the seal I used on my 1655. Number was provided by another member. Not sure of the 50 series axle size. You might check this out. Same seal for a lot less money than Agco.
Nice tractor btw.
Edited by dropped82, October 30, 2017 - 04:06 PM.
  • pryan05 said thank you
#5 pryan05 ONLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 30, 2017 - 04:06 PM
If you didn't order your seals yet, pull out an old one and bring it to a bearing supplier.  They will be able to match up the seal for much cheaper.  The axle seals for my Ford LGT are 16$can each.  Just trying to save a guy a buck!
Nice tractor!
  • dropped82 said thank you
#6 Cribs1450 OFFLINE
Cribs1450
  • 46 Thanks
  • 22 posts
Posted October 30, 2017 - 04:54 PM
Yep , Tried this the second time around.. Looks that the spring inside the rubber gets disturbed possibly.  Will try again though. Also saw in a thread that putting the seals inside a freezer for a few hours prior to installation could help!
#7 Cribs1450 OFFLINE
Cribs1450
  • 46 Thanks
  • 22 posts
Posted October 30, 2017 - 05:01 PM
Yes I thought so aswell.  If I bought state side I found the same size seals that were about 13 CAD from NAPA auto parts, but they are universal.  But at first I was looking to just purchase straight through AGCO dealer.  Also Thanks on the blade.  I was very fortunate with my setup as my PAPA was the head salesman at ADVANTAGE (Massey dealership in Essex County Ontario) so I was able to get the 1450 with front dozer blade, rear blade, tiller, about a 300 pound roller and a ground leveler when he passed.  This is one of the many reasons I am restoring everything in his memory!
  • limebuzz and pryan05 have said thanks
#8 GardnMastr OFFLINE
GardnMastr
  • 378 Thanks
  • 191 posts
Posted October 30, 2017 - 05:09 PM
Put some grease on the garter spring, inside the lip of the seal. It helps keep it from bouncing off the rubber lip. Also, put something thin and hard over the threads, like a post card, or wrap it with tape. I have old microfiche cards. Thin plastic I wrap around things, then slide the seal over.
  • MolonLabe and Cribs1450 have said thanks
#9 Cribs1450 OFFLINE
Cribs1450
  • 46 Thanks
  • 22 posts
Posted October 30, 2017 - 07:39 PM
I have not thought of doing this! thank you will try!
#10 Cribs1450 OFFLINE
Cribs1450
  • 46 Thanks
  • 22 posts
Posted October 30, 2017 - 07:46 PM
Nice tractor!
I will have to search essex county , to my knowledge I do not know any "bearing supplier" in the area!
#11 Cribs1450 OFFLINE
Cribs1450
  • 46 Thanks
  • 22 posts
Posted November 09, 2017 - 12:43 AM
picked up 2 for 38 $ CAD via Motion Canada .  should be in this week!
