John Deere TRS21
john deere single stage 2 cycle paddle
16 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted October 29, 2017 - 01:00 PM
I added this to the worker fleet and will add more details about it as I learn about it.  I know that it has a Tecumseh 2 cycle engine but don't know much else about it.  This one has a plug-in electric start like my little Snapper 18" unit.  Oil/Gas mix ratio is 50:1
  • Bolens 1000, EricFromPa and KennyP have said thanks
#2 EricFromPa OFFLINE
EricFromPa
  • 4,310 Thanks
  • 3,417 posts
Posted October 29, 2017 - 02:14 PM
Looks very similar to the Ariens I have. Different color and no electric start but it starts really easy. 3hp Tecumseh 2 stroke 21" wide.
Well it did start really easy untill I let it sit with gas in it for 2 months. I have the carb off of it. Float got ate up pretty bad.  Note to self (don't let snowblower sit out in the Sun with fuel in it again) lol
They will throw 8-10" deep snow if it's dry snow. They don't like the Wet stuff. I like how easy they are to maneuver. Perfect for a narrow side walk like ours.
Edited by EricFromPa, October 29, 2017 - 02:14 PM.
  • Trav1s said thank you
#3 shorty ONLINE
shorty
  • 5,922 Thanks
  • 5,453 posts
Posted October 29, 2017 - 02:23 PM
Spent a few hours behind a Toro of similar design. Lightweight and easy to move around.
#4 Bolens 1000 ONLINE
  • 15,564 Thanks
  • 18,321 posts
Posted October 29, 2017 - 03:49 PM
Neat looking unit
#5 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted October 30, 2017 - 09:27 AM
Here is the story behind this one...
I have been following these blowers for some time with hopes of upgrading from my little single stage Snapper.  This one showed up locally and was $50-100 less than others out there.  I contacted the seller and made arrangements to make the purchase.  The seller told me that he was selling it for his father-in-law who is no longer able to use it.  Before I got it the seller's father-in-law replace the belt and spark plug then gave it simple cleaning.  One pump on the primer (no choke) and it started on the first pull.
It does look similar to other singles out here but still have not done any research at this time.
  • shorty said thank you
#6 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted December 21, 2017 - 08:34 AM
Missing three M111113 bolts that hold the upper hood in place.  One of the members from my church works at the local Deere dealer and he is picking them up for me.  :-D
#7 Alc ONLINE
  • 7,357 Thanks
  • 7,639 posts
Posted December 21, 2017 - 09:02 AM
We thought about one of those for the sidewalk and carrying up 4 steps to our deck approx. 38' x 12'  Should be a good machine for you
#8 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted December 30, 2017 - 02:55 PM
While I am not happy how easily this one catches on the sidewalk joints, I used it last night to do the second round of clean up.  It is clear this one has a bigger engine than the Snapper I have been using.  It will take on 6" snow and not miss a beat.  Once I get the bolts for the hood I will take a look at the cutting edge and see if there is a way to make it move along the sidewalk and driveway a bit easier.
#9 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted January 15, 2018 - 04:37 PM
Installed the hood screws and washers this afternoon and used it to clean the 6-8" drift of snow out of the driveway.  Definitely got more grunt than the Snapper.  I also noticed the cutting edge has more wear than I initially realized.  I found an Oregon 73-022 on Amazon with free shipping but have found Deere M94511 cheaper elsewhere.  It definitely needs replaced sooner than later.
#10 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted January 16, 2018 - 04:08 PM
Ordered two scrapers while I was at it since the shipping cost was the same.  Once they are here and installed the little Snapper will be rehomed and this will be the keeper.
  • KennyP and Leonard VanCamp have said thanks
#11 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted January 27, 2018 - 04:44 PM
New edges arrived.  Deere parts number sticker over the Briggs stickers.  Installed the new edge and it looks much better than the worn piece that was on it.  With 45 degree temps it is hard to wish for snow to put it to work.  I'll pass and celebrate the nice weather the last weekend of January in Iowa.
  • Bolens 1000 and dodge trucker have said thanks
#12 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted January 27, 2018 - 05:14 PM
Deere # M94511 and Briggs # 302418MA
#13 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted February 06, 2018 - 10:32 AM
So I got this out yesterday to take care of the 4-6" of white love that we got yesterday.  New cutting edge works much better but there is still a problem with the cutting edge getting caught in the driveway and sidewalk expansion strips.  I found myself up against the handle bar multiple times.  This thing really needs some slide shoes on the outer edge that will prevent it from dropping into those spaces between the concrete.  I found these and will do some additional digging before I pull the trigger.  Most of these are for larger two stage units so I am confident they would be more than adequate for this machine.
https://www.ebay.com...msAAOSwtfhYri23
#14 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted February 06, 2018 - 10:35 AM
A cheaper option
https://www.amazon.c...s/dp/B00PBGM7RM
#15 Trav1s ONLINE
Trav1s
  • 3,651 Thanks
  • 4,605 posts
Posted February 06, 2018 - 10:38 AM
Then again the I might need to talk to my repair man and have him flip the scraper edge.
Edited by Trav1s, February 06, 2018 - 10:39 AM.
Also tagged with one or more of these keywords: john deere, single stage, 2 cycle, paddle
