Wanted
Spindle for ford/gilson/lawnboy 42/48 inch mower deck
7 replies to this topic
#1 Mustard Tiger ONLINE
Mustard Tiger
  • 93 Thanks
  • 116 posts
Posted October 28, 2017 - 09:01 PM
I am not sure what other models of tractor had these decks, but I've got the 18h.  I am just checking to see if anyone has a spindle for a reasonable price.  New ones are too expensive to be worth fixing it with.
#2 EricFromPa ONLINE
EricFromPa
  • 3,512 Thanks
  • 3,064 posts
Posted October 29, 2017 - 12:57 PM
need a NOS deck?
https://www.ebay.com...3UAAOSw8d5ZS-HS
You should be able to rebuild the spindles. Bearings don't cost very much. You should be able to take the spindles apart and bring the bearings in to your local Napa parts place and they will be able to match up a set of bearings for you.
  • Mustard Tiger said thank you
#3 Mustard Tiger ONLINE
Mustard Tiger
  • 93 Thanks
  • 116 posts
Posted October 29, 2017 - 07:01 PM
Yikes, no thanks.  I can't afford to be a collector, I am just in it for the cheapest way to take care of the grass/snow/garden/etc.  Replacing the bearings is fine, but one of the spindles is worn down badly and needs either fixed or replaced, and I am guessing replacing will be cheaper if I can find one.
#4 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted October 30, 2017 - 05:14 AM
If we had a model # for the deck then we might find a replacement spindle. Here's a link to some Lawn-Boy/Gilson spindles.
#5 Mustard Tiger ONLINE
Mustard Tiger
  • 93 Thanks
  • 116 posts
Posted October 30, 2017 - 07:07 AM
The decks were 63687A and 63688C.  The only place I found any was new from messicks, but for $300 it isn't worth fixing.
#6 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted October 30, 2017 - 07:32 AM
I can't get those #'s to work there. Did you get a spindle #?
#7 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted October 30, 2017 - 07:38 AM
Check this one out.
#8 Mustard Tiger ONLINE
Mustard Tiger
  • 93 Thanks
  • 116 posts
Posted October 30, 2017 - 09:40 AM
Messicks has the spindle listed as LB744691.  Unfortunately not the same as the jakes or the smaller 38 inch gilson decks which seem to be much more common.
Edited by Mustard Tiger, October 30, 2017 - 09:40 AM.
