im new here and to sears tractors, just acquired a super 12 my question is the switch will not kill the engine, am I right that the switch is supposed to be grounded when it goes back to stop and grounds out the engine? if I remember right the switch has a power in from battery, a power out to voltage regulator, a wire to the cigarette lighter and cant remember maybe one to amp meter then black wire that goes down towards the engine. There is also a wire that comes off the very base of the voltage regulator that has loop on it, this wire and the black wire from the switch are presently loose. So im waiting to confirm what I should do with them. I realize I also could have a bad switch? thanks for any help. Matt.
need sears super 12 electrical help please
#1
OFFLINE
Posted October 28, 2017 - 07:29 PM
- KennyP said thank you
#2
ONLINE
Posted October 29, 2017 - 05:51 AM
I posted an answer in your other thread for the diagram.
- boyscout862 said thank you
#3
ONLINE
Posted October 29, 2017 - 07:40 AM
Anytime you are doing electrical to your vintage or antique garden tractor never assume the color coding is correct. Many of these machine have been rewired at some point do to electrical issues or even mice and rats. Often we will see that they use what ever color wire is available so its best to check routing not wire color.
- boyscout862 and 4tom have said thanks
#4
ONLINE
Posted October 29, 2017 - 08:12 AM
Download the manuals from our Manuals Section. Be very careful when playing with the wiring on those old Tecumseh engines with electronic ignition. It is real easy to damage them and the parts are very expensive. Post clear pics of your problem areas so that we can see what you are talking about. Good Luck, Rick
#5
ONLINE
Posted October 29, 2017 - 08:22 AM
I can't agree more with that statement....That goes with anything electronic these days. Make sure the battery is disconnected and verify your wiring and connections before connecting the battery , verify it twice if your not 100% sure.
Edited by John Arsenault, October 29, 2017 - 08:22 AM.
#6
OFFLINE
Posted October 29, 2017 - 01:53 PM
#7
OFFLINE
Posted October 29, 2017 - 06:31 PM
#8
OFFLINE
Posted October 30, 2017 - 05:19 PM
#9
OFFLINE
Posted October 30, 2017 - 05:20 PM
#10
OFFLINE
Posted October 30, 2017 - 05:46 PM
#11
OFFLINE
Posted November 01, 2017 - 03:44 AM
