Bolens 1250 running rough
5 replies to this topic
#1 PJB1250 OFFLINE
PJB1250
  • 3 posts
Posted October 28, 2017 - 06:47 PM
So I bought my Bolens 1250 last week, I got it home and it’d only run on choke. So I thought no brainer the carb is gummed up. I took it apart and it was straight up nasty, so I ordered a rebuild kit. I got a Walbro carb with the deal which looked brand new and I opened it up and it was spotless. I put it on along with a new fuel filter, and it idles beautiful and even on half throttle runs good. When I pull it to full throttle it acts like the choke is on and cuts out and dies, has no power. I set the high idle needle to factory settings, 1.5 turns out and still nothing. I’ve tried adjusting it both ways and still runs like crap at full idle. Any suggestions?!
#2 EricFromPa OFFLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted October 28, 2017 - 09:27 PM
Sounds like the new carb is to small. Take a look at the inside diameter of the new carb VS the original carb. Betting the new carb is smaller on the inside just behind the choke plate.
#3 PJB1250 OFFLINE
PJB1250
  • 3 posts
Posted October 29, 2017 - 05:41 AM
Thanks for the reply. I believe it’s the right carb but I’ll definately look at it. It gets plenty of fuel when I back the needle out because it spits gas through the choke hole.
#4 boyscout862 ONLINE
  • 12,849 Thanks
  • 9,171 posts
Posted October 29, 2017 - 08:08 AM
Welcome to GTT. Download the manuals for the 1250 from our Manuals Section. Check the points too. Good Luck, Rick
#5 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted October 29, 2017 - 08:21 AM
:welcometogttalk: & :wewantpics: please.
#6 PJB1250 OFFLINE
PJB1250
  • 3 posts
Posted October 29, 2017 - 10:02 AM
Thanks for the add gents! I’ll
Be sure to check the points, that seems to be the logical
Cause. I figured if the points were dirty it wouldn’t start at all, but doing research...well I was wrong. I’ll let you guys know what I find. Thanks again.
