I have a 7012 factory kohler,has been repowered with a briggs 16hp. engine has 3 wires coming out of it. one is black with solid copper wire, red and white wires going to a plug. where do these 3 wires go? the tractor is key start,yet there is no voltage regulator. thanks for the help!
simplicity 7012 wiring issue
#1
OFFLINE
Posted October 27, 2017 - 08:41 PM
#2
ONLINE
Posted October 28, 2017 - 05:05 AM
I am not sure but guessing 2 wires goto the voltage regulator and 3rd maybe kill switch or 12 volt power
Need the model, spec number of the briggs and then check manual to make sure wires are correct
here is where the old briggs manuals are
https://www.briggsan...ifications.html
Need tractor manual to know where to hook engine wires up
Edited by James Bosma, October 28, 2017 - 05:09 AM.
- sodbuster10231 said thank you
#3
OFFLINE
Posted October 28, 2017 - 10:06 AM
thanks for the link.. manual does not help me much..or I just not seeing what I need.
#4
ONLINE
Posted October 28, 2017 - 04:34 PM
If you can post your model, spec, serial number of the engine I will see what i can find out for you
#5
OFFLINE
Posted October 29, 2017 - 06:16 PM
briggs model 326437
type 2527-01
code 92110948
tractor 1690357 (7012)
#6
ONLINE
Posted October 29, 2017 - 06:51 PM
seems 2 wires are alternator and other is kill switch
Which are which I am not sure and hope you can figure it out
Hope this helps some
Attached is parts manual for your engine
If engine runs use a 12v test light on the wires
Thinking the stranded wires are for alt and should light the light if working
If its a kill wire then engine should shut off when you hook test light to it
#7
OFFLINE
Posted January 22, 2018 - 09:01 PM
the black solid copper wire is the kill wire, it goes to the ignition coil, the red is the alt that charges the battery an it has a diode wired inline right by the plug to keep power from flowing back when motor is off so battery dont discharge. the white is acc power for lights. the stator is a 2 part one, half is for charging, half for powering lights.
- Dince and Alltractoredup have said thanks
