317 dual brakes
5 replies to this topic
#1 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 27, 2017 - 08:27 PM
Will 317 dual brakes transfer over to an open frame 316?
#2 Leonard VanCamp ONLINE
Leonard VanCamp
  • 490 Thanks
  • 381 posts
Posted October 27, 2017 - 08:30 PM
I believe they are a little different, you would probably do better with the brakes from a 318 or 420.
#3 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 27, 2017 - 08:31 PM
Ok, thanks!
#4 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted October 28, 2017 - 06:59 AM
There are significant changes in the frames between the closed frame 300 series (300/312/314/316K/317) and the open frame 300 series (316 Onan/318/322/330/332) which I why I pointed you to the 318 parts in the previous thread.  The move to open frame began in 1984 and there are rolling changes along that entire production run.  Finding parts from a 318 in the same approximate serial number range will make the swap easier.
  • KennyP and Dspangler have said thanks
#5 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 28, 2017 - 08:49 AM
Thanks Trav! The only reason I started this thread is because I found a decently priced parts 317 tractor.
  • Trav1s said thank you
#6 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted October 28, 2017 - 09:26 AM
If you can get it right, the parts from that machine can be used to upgrade 314s (and later 312s) and are in demand.  If you have the $ and the space, you could likely make some $ on it if the tractor is priced right.
