Ariens 48 inch snow blower deflector control
14 replies to this topic
#1 71mustangman OFFLINE
71mustangman
  • 62 Thanks
  • 93 posts
Posted October 27, 2017 - 12:39 AM
Hi there in the process of repairing my 48 inch blower. I would like to control the deflector chute from the drivers seat. I know ariens sells the cable for the deflector control but its 140.00 $ new . Just wondering if any one out there had some ideas. I was thinking of using a hood release cable or e-brake cable? went to lowes to look at a walk behind ariens blower and husquarna walk behind blower. Thanks Mustangman
#2 KennyP ONLINE
  • 40,877 Thanks
  • 47,091 posts
Posted October 27, 2017 - 05:56 AM
What about a garage door cable? They are long enough to get the length you need. And they have the small crimps for making a loop where you want.
#3 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted October 27, 2017 - 07:00 AM
I just threw out a 9 foot piece of stainless steel steering cable for a boat. I bet that would have worked great you can push or pull with that kind of cable. A bit thick and bulky but strong and long lasting. Would be a tad bit heavy gauges and won't make tight bends easily though but if your routing is simi straight it would work.
I was holding on to it because I was going to make a chute cable for my sears because after putting the new engine on the chute control rod now hits the engine, but I just bought a different style blower.
Anyway check out cablecraft
This is an example and not intended to be for your machine
https://www.ebay.com/itm/CABLECRAFT-Spoolvalve-Cable-Remote-Valve-Control-Lever-165-042-001-1-4-43B-72/253203322394?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D48754%26meid%3D46bc26b0ce9f4d2d8906c10e599d80f5%26pid%3D100005%26rk%3D1%26rkt%3D2%26sd%3D322820313994&_trksid=p2047675.c100005.m1851
#4 massey driver ONLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted October 27, 2017 - 07:53 AM
I used a electric window motor to control the deflector chute and a small winch for rotation on my Ariens blower.
#5 artbuc OFFLINE
artbuc
  • 107 Thanks
  • 185 posts
Posted October 28, 2017 - 03:38 AM
Very cool! Could you provide a few more details on your installation, including make/model number of winch and control switches? Thanks.
PS. What is the hydraulic cylinder doing?
Edited by artbuc, October 28, 2017 - 04:44 AM.
#6 massey driver ONLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted October 28, 2017 - 08:36 AM
I used this snowblower on a Massey tractor and now have it on my Kubota. The cylinder you see is part of the quick hitch aasy that's used to mount the blower to the tractor. The winch is just a cheap 1000 lb winch not sure of the make. The switches are doulble pole and double throw monentary switches. that are used to control the window motor as well as the movement of the winch. The wiring of the switches are a little tricky but can be done.You have to reverse the polarity of each side of the switches output terminals. in another words one side of the swirches terminals are a postive to negative and the other side is a negative to positive, Sounds confusing buts its no really. I do believe that you can buy some switch that has this built in feature.If you have and more questions feel free to ask and I'll try and help. I was looking for pics but can't seem to find them guess some stuff never got installed in my new Computer.The pics are from when I had it on the massey I don't have any yet showing it on the Kubota.
#7 71mustangman OFFLINE
71mustangman
  • 62 Thanks
  • 93 posts
Posted November 02, 2017 - 12:21 AM
Hi there folks just want to say thanks for all the great ideas concerning the deflector control. I will be working on that soon enough mustangman
#8 dodge trucker ONLINE
dodge trucker
  • 2,812 Thanks
  • 3,442 posts
Posted December 19, 2017 - 11:14 PM
As you may know I am rebuilding an Ariens 48" blower, and the chute cable to rotate the chute thru Ariens is $102 via Jack's and a couple of other places, seems like something that would be about 60 cents a foot at a hardware store, I found a cable that looks like the same one as Ariens uses, cost me $13 and that was right to my mailbox.
#9 Leonard VanCamp ONLINE
Leonard VanCamp
  • 658 Thanks
  • 473 posts
Posted December 19, 2017 - 11:34 PM
I used a electric actuator from Bailey Hydraulics, 4" throw and 270 lbs. load capacity, used a 6 pole double throw switch from NAPA wired like massey driver did. Actuator was about $35.
#10 71mustangman OFFLINE
71mustangman
  • 62 Thanks
  • 93 posts
Posted December 20, 2017 - 01:26 AM
Hi there dodge trucker where did you buy the cable from? part number and web site? thanks mustangman
#11 71mustangman OFFLINE
71mustangman
  • 62 Thanks
  • 93 posts
Posted December 20, 2017 - 01:34 AM
ok at baileys web site now can you please supply a part number for the actuator Thanks mustang man
#12 dodge trucker ONLINE
dodge trucker
  • 2,812 Thanks
  • 3,442 posts
Posted December 20, 2017 - 06:58 AM
part number is M116184 source was Ebay. It looks a lil heavier gauge than the old one but that could be just because it isn't 30+ years old, and hasn't been in a fire....
#13 71mustangman OFFLINE
71mustangman
  • 62 Thanks
  • 93 posts
Posted December 21, 2017 - 12:58 AM
just went on ebay looked up that number m116184 comes up with nothing
#14 Leonard VanCamp ONLINE
Leonard VanCamp
  • 658 Thanks
  • 473 posts
Posted December 21, 2017 - 01:07 AM
The Bailey book I have in my hands right now list the following model numbers, 139605, 139606, 139607, 139608 and 139609.
Edited by Leonard VanCamp, December 21, 2017 - 01:25 AM.
#15 71mustangman OFFLINE
71mustangman
  • 62 Thanks
  • 93 posts
Posted December 21, 2017 - 01:14 AM
thanks mustangman
